Inventory Adjustment Dashboard
Anyone ever create an dashboard to adjust inventory? If so, how did you do it?
Hello @Will79,
I’m assuming you are asking this as you have a need for doing bulk qty adjustments. If that’s the case then you might have a bigger issue with process that is requiring this need. Ideally the inventory should be looking after itself and cycle counts being used to make those additional adjustments as part of periodic procedure.
But if you have a need for one then perhaps DMT is a better option.
I am only asking because the owner of my company is asking to do this in an Dashboard. I’ve never done this with a DMT though. Wil have to figure that one out.
Quantity Adjust and Inventory Transfer are both kind of like dashboard forms. They work great and are built-in! But if you need to make changes to a huge set of data, the DMT is the way to go!
Not to say that a dashboard for inventory adjust is impossible, but there are so many methods you have to trace down. It is a real headache. Make sure you really need to do it before you attempt this!
