Quantity adjustments in a batch
Hello Experts,
Is there a way to do quantity adjustments in a batch? could you guys please let me know if there is.
Thank you
DMT is the tool for this
In addition to DMT, which we have used, you could also use a Cycle Count to update quantities in batch.
Mark W.
I believe you can copy from Excel and paste insert into the List view tab.
Thank you Jose.
Thanks Mark,
I haven’t heard about it before. So could you please explain the procedure about the Cycle count. is it a add-on to Epicor or i can find it in Epicor?
Thanks Matt,
I couldn’t find the list view tab in Quantity Adjustment form.
Hello Niraj,
You will find the Cycle Count programs under Inventory Management and an explanation of the process in the Epicor Application User Guide available on EpicWeb for your version of Epicor ERP.
Mark W.
Now that I’m looking, I don’t see it either. I could swear there was a List view at some release level - maybe it was early Vantage 8. My apologies for the confusion. Cycle Counting is the best way to manage large amounts of adjustments, especially if you do not have DMT.
Thanks Matt, I have decided to use DMT now.
Thanks Mark,
I am going to use DMT . :slight_smile:
Great! That’s the best tool. FYI, I was thinking about Cost Adjustment, not Quantity Adjustment, which allows a copy and paste-insert of new records. My apologies for the confusion earlier.
