Opps, you are right
Andrew Best
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf
Of Jim Frice
Sent: Friday, February 15, 2008 11:55 AM
To:
Subject: RE: RE: [Vantage] Invoicing
Andrew,
Are you sure? If you flag the receipt line as not received complete that
is then reopening the PO line therefore the PO is open not closed
anymore. The receipt entry is what typically closes the PO's not the A/P
invoice entry.
Jim
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
[mailto:
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
Behalf
Of Ken Williams
Sent: Friday, February 15, 2008 11:42 AM
To:
Thanks for the heads up. That is a much better workaround then a misc.
invoice.
Ken
[mailto:
Behalf
Of Andrew Best
Sent: Friday, February 15, 2008 10:34 AM
To:
The PO is not reopened by the receive complete button being unchecked,
it just allows for a another invoice.
Andrew Best
[mailto:
Behalf
Of Jeni Wilson
Sent: Friday, February 15, 2008 11:30 AM
To:
We are still on 6.1 so this might not work for you, but couldn't you
un-receive the line for "2" , change the po line to "1" and enter a
second line on the po for "1" and receive in both lines. The purchase
order will be closed, you do not have to remember anything and the
invoices can be paid separate.
Jeni Wilson
Boyer Machine
mailto:vantage%40yahoogroups.com <mailto:vantage%40yahoogroups.com>
[mailto:
Behalf Of Ken Williams
Sent: Friday, February 15, 2008 12:25 PM
To:
Subject: RE: [Vantage] Invoicing
The problem is, no one knows until the invoice arrives that the supplier
for whatever reason has split the invoice in two.
The PO has been received complete, if you go back into receipt entry and
uncheck received complete, does it now re-open the PO line? Do you go
back in and check complete when the other invoice comes? Seems like a
lot of manual tracking and steps to do what I believe the system should
allow for in the first place. If we receive 2 on one receipt and get
invoiced twice for 1 each, I should be able to tie both of those in
without having to rely on a received complete checkbox that should be
checked.
<mailto:vantage%40yahoogroups.com> [mailto:
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>]
On Behalf
Of Andrew Best
Sent: Friday, February 15, 2008 10:17 AM
To:
Vantage is treating the "Receive complete" button as the PO has been
received complete. If you uncheck the "receive complete" button, you
can still pay the invoice for 1 and then enter and pay the next invoice
for 1 more.
Andrew Best
[mailto:
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ]
On
Behalf
Of Ken Williams
Sent: Friday, February 15, 2008 11:13 AM
To:
But he has received it complete. The supplier invoiced seperately for
whatever reason.
In my case it hasn't mattered if it's stock or non-stock, same results.
When you bring in an invoice to a receipt and change the quantity, it
should leave the receipt open to invoice the other quantity later.
Instead it marks the entire receipt paid and the only work around I've
been able to come up with is a misc. invoice.
[mailto:
Behalf
Of Andrew Best
Sent: Friday, February 15, 2008 10:10 AM
To:
Make sure the "receive Complete" button is not checked.
Are you purchasing to stock or a none-stock item?
Andrew Best
[mailto:
Behalf
Of Bill Finn
Sent: Friday, February 15, 2008 11:06 AM
To:
Subject: [Vantage] Invoicing
We are running 8.3.305K. We have the following Scenario;
I enter a Purchase Order for 2 pcs of part# ABC. I receive both on the
same pack list on the same day. When we receive the invoice, we only get
invoiced for 1 of the 2 that were received. If we go iin and enter the
invoice, changing the qty to 1 and then going through all the normal
machinations (I am not in accounting lol), everything works just fine.
However, when the second invoice comes in we are unable to enter that
invoice against that PO/Line/Receipt. Any ideas? Our accountant came to
me this AM to run some tests in our sandbox environment but I can't see
how we could do anything differently? thanks in advance for any help.
bill
Looking for last minute shopping deals? Find them fast with Yahoo!
Search.
