Invoicing with AutoPrint BPM
Hi, I created a group with 2 invoices in AR invoice entry. I posted the invoices, but the last step is to EDI the invoices using a BPM and report style. Essentially, the BPM checks if the EDIReady flag is set to true; and then creates the EDI text file (invoice) using the report style. I get the following error from the System Monitor:
Failed to submit autoprint report. Error: Ice.BLException: No invoices selected to print.
at Erp.Services.Rpt.ARInvFormSvc.ExValidateParam() in C:_releases\ERP\ERP10.2.700.0\Source\Server\Services\Rpt\ARInvForm\ARInvForm.cs:line 314
at Ice.Core.TaskServiceBase`1.SubmitUsingTaskAgent(IceRow parameterRow, String agentID, Int64 agentSchedNum, Int32 agentTaskNum, String maintProgram) in C:_Releases\ICE\ICE3.2.700.0\Source\Server\Internal\Lib\TaskLib\TaskBase\TaskServiceBase.cs:line 311
at Erp.Services.Rpt.ARInvFormSvc.SubmitToAgent(ARInvFormTableset ds, String agentID, Int64 agentSchedNum, Int32 agentTaskNum, String maintProgram) in C:_releases\ERP\ERP10.2.700.0\Source\Server\Services\Rpt\ARInvForm\ARInvForm.Designer.cs:line 116
at Epicor.Customization.Bpm.DBD9BE451FA1DE4A9CA3A80A657AF9A0DD.PostTranDirective_EDIAutoprint_C6CE8334C0164E87A1B00C5C5CEC2664.A001_AutoPrintAction()
Any assistance would be gladly appreciated.
Tony
Problem solved. One of the Report Parameters returned to default when I changed the report style.
can you send me the code how you are calling the BPM to auto print. I am also trying to achieve the same thing.
