Thanks for the info but I see this as a pretty extreme workaround
and I don't always want to print the tag. If others out there have
similar issues, I have created an enhancement request 12566MPS for a
method to print issued material tags from the Issue Material
interface. It seems to me that this should be a standard function??
Rich J @ ERMC
Rich J @ ERMC
--- In vantage@yahoogroups.com, "Aaron Hoyt" <aaron.hoyt@...> wrote:
> For speed, I can't tell you, only because I have not tried to
compile a
> crystal report and distribute it for this purpose. We are
printing this
> using Data collection licenses and use as a trigger the
JobMtl.IssuedQty
> field. I first verify it's more than 0 (eliminate record
creations) and
> then compare it to the old issued quantity. If it's greater, it's
an issued
> quantity label and I process the logic for having issued material
to the
> job, if it's less I process the logic for return quantity and
print labels
> for return to stock. We do barcode the return labels (only the
part number
> and quantity for ease of inventory at month end), but most the
labels we
> print do not include barcodes at this time. Most of the labels
are to
> comply with our ISO system and it's identification requirements.
> The whole process of reporting an issue of material and waiting
for the
> label to print take about 15 to 20 seconds by estimation. Of
that, maybe 5
> to 7 seconds is waiting for the Wasp software to load and start
printing the
> label. This is just estimation, but it's been a long time since
we have had
> any credible complaints about the speed of the labels.
> Aaron Hoyt
> Vantage Plastics
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On
Behalf Of
> ermc_v
> Sent: Monday, October 09, 2006 10:28 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Issue Material Tags
> Thanks for the response. I would like to understand how your BAM
is
> set up, or what you are using as a trigger to generate the report
> info. I see Wasp is primarily a barcode software. We are
currently
> not applying bar codes to our inventory. Do you find this to
> faster than generating a Crystal report?
> Rich J
> --- In vantage@yahoogroups.com, "Aaron Hoyt" <aaron.hoyt@> wrote:
> > Rich,
> > We do it via a BAM using Wasp Labeler. I can share the details
if
> you wish.
> > We print issued labels, return labels, report quantity labels,
end
> activity
> > labels, end setup labels, receive from Mfg labels, receive to
> inventory from
> > Purchase labels...All based on BAMs using Wasp Labeler
(because it
> was cheap
> > and command line accessible).
> > Aaron Hoyt
> > Vantage Plastics
On
> Behalf Of
> > ermc_v
> > Sent: Monday, October 09, 2006 9:51 AM
> > Subject: [Vantage] Issue Material Tags
> > Has anyone found a way to print material tags when issuing
> material
> > from inventory? The Issue Material screen data is a temp table
> that
> > can't be accessed via Crystal.
> > Rich J
> > ERMC
