Job Material Blank Title 112311
I may be wrong.. but you could shake this out, if you have a purchase to job material, and when you schedule that job, and do not ignore constrained materials, the operational start date that the material is tied to will be based on the expected receipt date of that material. As to standard visibility to that condition, I think you could easily write a report to see that condition, but that assumes the job has been scheduled. It might get a little complex to back date from that operation through the critical path to the start of the job itself.
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
[Description: cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Greg Payne
Sent: Thursday, July 19, 2012 5:13 PM
Subject: [Vantage] Job Material
We order material for each job. I need to know when the final material will arrive, so we can plan the start date of the job.
Does Epicor store or calculate this information or do I need to write my own? I have looked at Multi Level Pegging, but it shows nothing.
Thanks for any suggestions.
Greg Payne
Compulink Cable Assemblies
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at (727) 578-6258 and immediately delete the communication.
Greg Payne
