Job pulling in the wrong material E9 version 604
Scott - you may be right - I just tried that and of course it doesn't remind
you to pull in the correct material but just leaves the old material there.
I shall put it down to Operator Error.
Thanks to all of you that replied
Adrian
Scott Way
Sent: 30 April 2012 20:41
Subject: [Vantage] Re: Job pulling in the wrong material E9 version 604
Was the job created from MRP or hand created?
If it was hand created, I can see where the user created a job using
part "380906", populated the Job Material from part "308906" BOM and
then realizing a mistake changes the part on the job to 380606 and does
not delete and repopulate the job with the correct BOM.
From the outside it looks like the job populated with the wrong BOM data
but it did not. If you can't recreate the problem, I will bet my
morning cup of coffee this is what happened. I know it because it has
happened here too.
This message is a CONFIDENTIAL communication.
If you are not the intended recipient, please do not
read, copy, disclose or use it. Additionally, please
notify the sender of the delivery error by replying to
this message, and delete it from your system.
Thank you.
For more information about M.I.C. Industries, Inc.,
please visit our website at: http://www.micindustries.com
We have created a job for a part but the material that has been pulled in is material for a different part. The two part numbers are very similar except that one digit is a 9 on one and a 6 on the other. This has then resulted in New PO Suggestions trying to buy the wrong materials.
Has anyone else seen this happen? I can't see how it could be operator error unless they manually entered each material off of a crib sheet for the wrong item - but why do that?
Adrian
Are you ABSOLUTELY sure that the boms are different?
I had one guy swear to me that they were but when we actually checked the revisions in the engineering workbench it turns out he copied one over the other!
M. Manasa Reddy
manasa@...<mailto:manasa@...>
630.806.2000 x1515
Ex scientia, vera
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of adrian.lauchlan
Sent: Monday, April 30, 2012 11:31 AM
Subject: [Vantage] Job pulling in the wrong material E9 version 604
Adrian
Total Control Panel
Login<https://asp.reflexion.net/login?domain=weldcoa.com>
To: manasa@...<https://asp.reflexion.net/address-properties?aID=516126014&domain=weldcoa.com>
From: sentto-20369-109757-1335803473-manasa=weldcoa.com@...<https://asp.reflexion.net/address-properties?aID=649836099&domain=weldcoa.com>
Message Score: 30
High (60): Pass
My Spam Blocking Level: Low
Medium (75): Pass
Low (90): Pass
Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-address=1&rID=516126014&aID=649836099&domain=weldcoa.com> this sender
Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-domain=1&rID=516126014&aID=649836099&domain=weldcoa.com> returns.groups.yahoo.com
This message was delivered because the content filter score did not exceed your filter level.
I am today - and checked the BoMs through the Engineering WorkBench. There
have been several changes to the revisions - is there any way of seeing what
was in each change?
Manasa Reddy
Sent: 30 April 2012 17:38
Subject: RE: [Vantage] Job pulling in the wrong material E9 version 604
other!
M. Manasa Reddy
manasa@... <mailto:manasa%40weldcoa.com> <mailto:manasa@...
<mailto:manasa%40weldcoa.com> >
630.806.2000 x1515
Ex scientia, vera
Adrian
Total Control Panel
To: manasa@... <mailto:manasa%40weldcoa.com>
om> &domain=weldcoa.com>
<mailto:sentto-20369-109757-1335803473-manasa%3Dweldcoa.com%40returns.groups
.yahoo.com> <https://asp.reflexion.net/address-properties?aID=649836099
Message Score: 30
High (60): Pass
Medium (75): Pass
Low (90): Pass
sender
your filter level.
The only way to see changes is if your guys recorded the changes (and then look at the audit log) or kept the old revision and you can do a revision compare.
When you create / modify / whatever and you go to check the part back in, the system asks you to record the changes, but they don't have to. You can bypass that screen and not record anything.
Just depends on your business process.
M. Manasa Reddy
630.806.2000 x1515
Ex scientia, vera
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Adrian Lauchlan
Sent: Monday, April 30, 2012 12:07 PM
was in each change?
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Manasa Reddy
other!
M. Manasa Reddy
manasa@...<mailto:manasa%40weldcoa.com> <mailto:manasa%40weldcoa.com> <mailto:manasa@...<mailto:manasa%40weldcoa.com>
630.806.2000 x1515
Ex scientia, vera
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Adrian
Total Control Panel
To: manasa@...<mailto:manasa%40weldcoa.com> <mailto:manasa%40weldcoa.com>
sentto-20369-109757-1335803473-manasa=weldcoa.com@...<mailto:sentto-20369-109757-1335803473-manasa%3Dweldcoa.com%40returns.groups.yahoo.com>
.yahoo.com<mailto:sentto-20369-109757-1335803473-manasa%3Dweldcoa.com%40returns.groups%0b.yahoo.com>> <https://asp.reflexion.net/address-properties?aID=649836099
Message Score: 30
High (60): Pass
Medium (75): Pass
Low (90): Pass
sender
your filter level.
Total Control Panel
From: sentto-20369-109760-1335805632-manasa=weldcoa.com@...<https://asp.reflexion.net/address-properties?aID=649912801&domain=weldcoa.com>
Message Score: 30
High (60): Pass
Medium (75): Pass
Low (90): Pass
Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-address=1&rID=516126014&aID=649912801&domain=weldcoa.com> this sender
Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-domain=1&rID=516126014&aID=649912801&domain=weldcoa.com> returns.groups.yahoo.com
I am retiring, so please remove my name from the group. I have gleaned
a tremendous amount of information from this group, keep up the good
work.
Frances Skidmore
Entek Corporation
3106 Broce Drive
Norman, OK 73072
(405)364-5588 Phone
(405)364-4727 FAX
Frances@...
Congrats on your retirment.
you can remove yourself from the group, click on edit menbership (next to your name above the blue bar vantage...) then on the lower righthand corner of your profile, click leave group).
good luck!
> work.
> Thanks,
> Frances Skidmore
> Entek Corporation
> 3106 Broce Drive
> Norman, OK 73072
> (405)364-5588 Phone
> (405)364-4727 FAX
> Frances@...
They have just overwritten the existing revision and put into the audit log
No change :-)
Manasa Reddy
Sent: 30 April 2012 19:00
compare.
M. Manasa Reddy
630.806.2000 x1515
Ex scientia, vera
was in each change?
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>] On
Behalf Of
Manasa Reddy
other!
M. Manasa Reddy
<mailto:manasa@... <mailto:manasa%40weldcoa.com>
630.806.2000 x1515
Ex scientia, vera
Adrian
Total Control Panel
> &domain=weldcoa.c
.yahoo.com>
.yahoo.com>
%0b.yahoo.com%3cmailto:sentto-20369-109757-1335803473-manasa%3Dweldcoa.com%4
> &domain=weldcoa.c
Message Score: 30
High (60): Pass
Medium (75): Pass
Low (90): Pass
sender
your filter level.
Total Control Panel
<mailto:sentto-20369-109760-1335805632-manasa%3Dweldcoa.com%40returns.groups
.yahoo.com> <https://asp.reflexion.net/address-properties?aID=649912801
Message Score: 30
High (60): Pass
Medium (75): Pass
Low (90): Pass
sender
your filter level.
SO wait a minute...then the two revisions are the same? Which would explain why your job has the other material in it, correct?
M. Manasa Reddy
630.806.2000 x1515
Ex scientia, vera
Sent: Monday, April 30, 2012 1:37 PM
No change :-)
Manasa Reddy
compare.
M. Manasa Reddy
630.806.2000 x1515
Ex scientia, vera
was in each change?
Behalf Of
Manasa Reddy
other!
M. Manasa Reddy
<mailto:manasa@...<mailto:manasa%40weldcoa.com> <mailto:manasa%40weldcoa.com>
630.806.2000 x1515
Ex scientia, vera
Adrian
Total Control Panel
> &domain=weldcoa.c
0returns.groups%0b.yahoo.com<mailto:sentto-20369-109757-1335803473-manasa%3Dweldcoa.com%40returns.groups%0b%3cmailto:sentto-20369-109757-1335803473-manasa%3Dweldcoa.com%40returns.groups%0b%0b.yahoo.com%3cmailto:sentto-20369-109757-1335803473-manasa%3Dweldcoa.com%254%0b0returns.groups%0b.yahoo.com>>
rns.groups%0b.yahoo.com<mailto:sentto-20369-109757-1335803473-manasa%3Dweldcoa.com%40retu%0brns.groups%0b.yahoo.com>>>
> &domain=weldcoa.c
Message Score: 30
High (60): Pass
Medium (75): Pass
Low (90): Pass
sender
your filter level.
Total Control Panel
sentto-20369-109760-1335805632-manasa=weldcoa.com@...<mailto:sentto-20369-109760-1335805632-manasa%3Dweldcoa.com%40returns.groups.yahoo.com>
.yahoo.com<mailto:sentto-20369-109760-1335805632-manasa%3Dweldcoa.com%40returns.groups%0b.yahoo.com>> <https://asp.reflexion.net/address-properties?aID=649912801
Message Score: 30
High (60): Pass
Medium (75): Pass
Low (90): Pass
sender
your filter level.
Total Control Panel
From: sentto-20369-109764-1335811007-manasa=weldcoa.com@...<https://asp.reflexion.net/address-properties?aID=650109378&domain=weldcoa.com>
Message Score: 87
High (60): Fail
Medium (75): Fail
Low (90): Pass
Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-address=1&rID=516126014&aID=650109378&domain=weldcoa.com> this sender
Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-domain=1&rID=516126014&aID=650109378&domain=weldcoa.com> returns.groups.yahoo.com
No - we have two products which have very similar part numbers - only
difference is one digit - let's say they are 380906 and 380606 - they have
two different BoMs but somehow the materials for Part 1 has ended up in Part
2 when a job was raised. But when I look at each Part and their respective
BoMs they are correct. So I cannot see how the Materials for Part 1 ended up
in a job for Part 2. I have tried to recreate it but the job pulls in all
the correct materials. All I can think is that Part 2's revision was
accidentally updated with the wrong parts then a job was raised. Someone
realised the mistake, corrected the BoM but didn't correct the job which was
found.
That is my assumption but I am concerned in case there is a possibility that
Epicor got confused because of the similarity in part numbers and loaded the
wrong materials into the job
Manasa Reddy
Sent: 30 April 2012 19:57
M. Manasa Reddy
630.806.2000 x1515
Ex scientia, vera
No change :-)
Behalf Of
Manasa Reddy
compare.
M. Manasa Reddy
630.806.2000 x1515
Ex scientia, vera
was in each change?
Behalf Of
Manasa Reddy
other!
M. Manasa Reddy
630.806.2000 x1515
Ex scientia, vera
Adrian
Total Control Panel
> &domain=weldcoa.c
> &domain=weldcoa.c
.yahoo.com>
.yahoo.com>
ups%0b.yahoo.com%3cmailto:sentto-20369-109757-1335803473-manasa%3Dweldcoa.co
> &domain=weldcoa.c
> &domain=weldcoa.c
Message Score: 30
High (60): Pass
Medium (75): Pass
Low (90): Pass
sender
your filter level.
Total Control Panel
> &domain=weldcoa.c
.yahoo.com>
.yahoo.com>
%0b.yahoo.com%3cmailto:sentto-20369-109760-1335805632-manasa%3Dweldcoa.com%4
> &domain=weldcoa.c
Message Score: 30
High (60): Pass
Medium (75): Pass
Low (90): Pass
sender
your filter level.
Total Control Panel
<mailto:sentto-20369-109764-1335811007-manasa%3Dweldcoa.com%40returns.groups
.yahoo.com> <https://asp.reflexion.net/address-properties?aID=650109378
Message Score: 87
High (60): Fail
Medium (75): Fail
Low (90): Pass
sender
your filter level.
Two possibilities, neither one of which can probably be proven now L
- When the job was first created the BOM was wrong, and
correcting the part BOM later doesn't fix existing jobs.
- In job entry, you can change the material part number,
somebody may have "fixed" a job incorrectly
We've had both happen a couple of times. If it's a regular problem,
turn on change logs, but if they're not already on, no real way to prove
what happened.
Brian.
Of Adrian Lauchlan
Sent: Monday, April 30, 2012 3:09 PM
have
Part
respective
ended up
all
was
found.
that
the
Behalf Of
Manasa Reddy
explain
M. Manasa Reddy
630.806.2000 x1515
Ex scientia, vera
log
No change :-)
On
Behalf Of
Manasa Reddy
then
revision
compare.
in,
can
M. Manasa Reddy
630.806.2000 x1515
Ex scientia, vera
On
There
what
was in each change?
On
Behalf Of
Manasa Reddy
the
the
other!
M. Manasa Reddy
630.806.2000 x1515
Ex scientia, vera
On
in is
except
resulted in
error
wrong
Adrian
Total Control Panel
a.c
> &domain=weldcoa.c
> &domain=weldcoa.c
sentto-20369-109757-1335803473-manasa=weldcoa.com@....c
om
oups.yahoo.com>
oups
.yahoo.com>
oups
.yahoo.com>
oups
oups
om%4
retu
oups
oups
om%4
retu
oups
oups
om%4
a%3D
mana
1097
retu
.gro
a.co
eldc
a.c
> &domain=weldcoa.c
> &domain=weldcoa.c
Message Score: 30
High (60): Pass
Medium (75): Pass
Low (90): Pass
126
this
sender
260
exceed
your filter level.
Total Control Panel
a.c
> &domain=weldcoa.c
sentto-20369-109760-1335805632-manasa=weldcoa.com@....c
om
oups.yahoo.com>
oups
.yahoo.com>
oups
.yahoo.com>
oups
oups
om%4
retu
a.c
> &domain=weldcoa.c
Message Score: 30
High (60): Pass
Medium (75): Pass
Low (90): Pass
126
this
sender
260
exceed
your filter level.
Total Control Panel
a.c
sentto-20369-109764-1335811007-manasa=weldcoa.com@....c
om
oups.yahoo.com>
oups
a.c
Message Score: 87
High (60): Fail
Medium (75): Fail
Low (90): Pass
126
this
sender
260
exceed
your filter level.
I see...and that sounds like your culprit.
But I have not played with E9 to say that there isn't a bug for getting the details.
Look through the other emails on the list, I could have sworn that Jennifer Lisser mentioned issues with get details in version E9, but I am not sure which patch had the issues.
M. Manasa Reddy
630.806.2000 x1515
Ex scientia, vera
Sent: Monday, April 30, 2012 2:09 PM
found.
Manasa Reddy
M. Manasa Reddy
630.806.2000 x1515
Ex scientia, vera
No change :-)
Behalf Of
Manasa Reddy
compare.
M. Manasa Reddy
630.806.2000 x1515
Ex scientia, vera
was in each change?
Behalf Of
Manasa Reddy
other!
M. Manasa Reddy
630.806.2000 x1515
Ex scientia, vera
Adrian
Total Control Panel
> &domain=weldcoa.c
> &domain=weldcoa.c
57-1335803473-manasa%3Dweldcoa.com%254%0b0returns.groups%0b.yahoo.com<mailto:sentto-20369-109757-1335803473-manasa%3Dweldcoa.com%40returns.groups%0b%3cmailto:sentto-20369-109757-1335803473-manasa%3Dweldcoa.com%40returns.groups%0b%0b.yahoo.com%3cmailto:sentto-20369-109757-1335803473-manasa%3Dweldcoa.com%254%0b0returns.groups%0b.yahoo.com%3cmailto:sentto-20369-109757-1335803473-manasa%3D%0bweldcoa.com%40returns.groups%0b%3cmailto:sentto-20369-109757-1335803473-mana%0bsa%3Dweldcoa.com%40returns.groups%0b%0b.yahoo.com%3cmailto:sentto-20369-1097%0b57-1335803473-manasa%3Dweldcoa.com%254%0b0returns.groups%0b.yahoo.com>>>
m%40retu%0brns.groups%0b.yahoo.com<mailto:sentto-20369-109757-1335803473-manasa%3Dweldcoa.com%40retu%0b%3cmailto:sentto-20369-109757-1335803473-manasa%3Dweldcoa.com%40retu%0brns.gro%0bups%0b.yahoo.com%3cmailto:sentto-20369-109757-1335803473-manasa%3Dweldcoa.co%0bm%40retu%0brns.groups%0b.yahoo.com>>
oa.com%40retu%0brns.groups%0b.yahoo.com<mailto:sentto-20369-109757-1335803473-manasa%3Dweldc%0boa.com%40retu%0brns.groups%0b.yahoo.com>>>>
> &domain=weldcoa.c
> &domain=weldcoa.c
Message Score: 30
High (60): Pass
Medium (75): Pass
Low (90): Pass
sender
your filter level.
Total Control Panel
> &domain=weldcoa.c
0returns.groups%0b.yahoo.com<mailto:sentto-20369-109760-1335805632-manasa%3Dweldcoa.com%40returns.groups%0b%3cmailto:sentto-20369-109760-1335805632-manasa%3Dweldcoa.com%40returns.groups%0b%0b.yahoo.com%3cmailto:sentto-20369-109760-1335805632-manasa%3Dweldcoa.com%254%0b0returns.groups%0b.yahoo.com>>
rns.groups%0b.yahoo.com<mailto:sentto-20369-109760-1335805632-manasa%3Dweldcoa.com%40retu%0brns.groups%0b.yahoo.com>>>
> &domain=weldcoa.c
Message Score: 30
High (60): Pass
Medium (75): Pass
Low (90): Pass
sender
your filter level.
Total Control Panel
sentto-20369-109764-1335811007-manasa=weldcoa.com@...<mailto:sentto-20369-109764-1335811007-manasa%3Dweldcoa.com%40returns.groups.yahoo.com>
.yahoo.com<mailto:sentto-20369-109764-1335811007-manasa%3Dweldcoa.com%40returns.groups%0b.yahoo.com>> <https://asp.reflexion.net/address-properties?aID=650109378
Message Score: 87
High (60): Fail
Medium (75): Fail
Low (90): Pass
sender
your filter level.
Total Control Panel
From: sentto-20369-109767-1335812916-manasa=weldcoa.com@...<https://asp.reflexion.net/address-properties?aID=650179078&domain=weldcoa.com>
Message Score: 87
High (60): Fail
Medium (75): Fail
Low (90): Pass
Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-address=1&rID=516126014&aID=650179078&domain=weldcoa.com> this sender
Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-domain=1&rID=516126014&aID=650179078&domain=weldcoa.com> returns.groups.yahoo.com
happened here too.
Thank you.
