Labor Exception Report
I do believe you can have the shop warning report in labor entry. I assume that is where you enter your qty completed. Just check off report in Labor entry.
Kathy Hambleton
Electron Energy Corp
Sent: Tuesday, May 13, 2003 2:22 PM
Subject: [Vantage] Re: Labor Exception Report
That does sound like a great tool. Unfortunately, we are not using
the data collection module. Does anyone know of another convenient
way of getting this info?
Kelly Wendorff
--- In vantage@yahoogroups.com, "Kathy Hambleton" <kbh@e...> wrote:
> We use this shop warning and it works great. Just set your % at
> whatever you want and every time the completed is over that
percentage
> it will send an alert to whoever you set up to get that alert. Like
I
> said it works great.
> Kathy Hambleton
> Electron Energy Corporation
> From: sarah.vareschi@n... [mailto:sarah.vareschi@n...]
> Sent: Tuesday, May 13, 2003 11:54 AM
> Subject: RE: [Vantage] Labor Exception Report
> It's not a report, but there is a Shop Warning for this that you
could
> set-up to send an email whenever this occurs -you can even put in a
> (I've
> never used this, but from reading the description, it sound like it
will
> give you what you want.)
must
> have already linked your email address to a yahoo id to enable
access. )
Builder
> and Crystal Reports and other 'goodies', please goto:
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
I need a report that alerts me when our completed quantity exceeds the job
quantity (and by how many pieces). We routinely overrun a job by a few
pieces, but I need to raise a flag when the overrun quantity is greater than
a certain %. There are times when an operator runs the same part back to
back and does not punch between jobs - this is what I need to capture....
Any suggestions or does anyone have a report that I can modify to achieve
this?
Thanks!
Kelly Wendorff
Cost Accounting Manager
SteelCraft Corp
105 SteelCraft Drive
Hartford, WI 53027
262-673-6770 ext 195
262-673-4380 Fax
Job operation record has the RunQty, QtyComplete and LastLaborDate. You may
want to start there.
Patrick Winter
Sent: Tuesday, May 13, 2003 10:34 AM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] Labor Exception Report
this?
Thanks!
Kelly Wendorff
SteelCraft Corp
Hartford, WI 53027
262-673-4380 Fax
It's not a report, but there is a Shop Warning for this that you could
set-up to send an email whenever this occurs -you can even put in a % (I've
never used this, but from reading the description, it sound like it will
whatever you want and every time the completed is over that percentage
it will send an alert to whoever you set up to get that alert. Like I
Kathy Hambleton
From: sarah.vareschi@... [mailto:sarah.vareschi@...]
(I've
Kelly Wendorff
percentage
I
> Kathy Hambleton
could
> (I've
will
must
access. )
Builder
Never mind my last post - I found the shop warnings. Looks great!
Thanks everyone.
Kelly
--- In vantage@yahoogroups.com, "wendorff1" <kelly.wendorff@s...>
> Thanks,
> Kelly Wendorff
> percentage
Like
> I
> > Kathy Hambleton
> could
a
> > (I've
it
> will
> must
> access. )
> Builder
