Large Blanket Jobs with Full Raw Material Traceability
What problems arise if you lot track and use serial numbers? Is that a version specific problem? We are on 8.03.408.
We are beginning to implement lot tracking and serial numbers on certain part numbers and so far through testing, I have not seen any problems using lot tracking and serial numbers on these parts.
Virginia Joseph
Deep Hole Specialists, LLC
440-543-8157
--- In vantage@yahoogroups.com, "Manasa Reddy" <manasa@...> wrote:
> Also you cannot lot track if you use serial numbers! Or you cannot use
> serial numbers if you lot track! Just so you know...
> Manasa
> 630.806.2000 x1515
> Of Scott Kaufman
> Sent: Tuesday, July 05, 2011 4:06 PM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Re: Large Blanket Jobs with Full Raw Material
> Traceability
> Thanks Virginia,
> We were told that you can only use serial numbers with a quantity of 1.
> We might add 150gm of one lot and 300gm of another lot to produce 3000
> cards(finished product) that has its own unique lot. These quantities
> would vary between runs.
> Scott
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf Of Virginia Joseph
> Sent: Tuesday, July 05, 2011 3:14 PM
> Subject: [Vantage] Re: Large Blanket Jobs with Full Raw Material
> Traceability
> Have you looked into using Serial Numbers? This would allow you to
> assign serial numbers to all raw materials when you receive them to
> inventory and specify which serial numbers are issued to jobs to satisfy
> material requirements. You can then assign serial numbers to the
> finished product when you receive them to inventory. When you ship to
> your customer from inventory, you can select which serialized parts you
> are shipping and the serial numbers would print on the packing slip. I
> think this would give you the traceability you need from customer
> shipment back to raw materils. Since you are a 24/7 operation, if you
> want your machinists to issue material to the jobs as they consume it,
> you can implement AMM and using MES the machinists can issue material
> from inventory (specifying which serail numbers are being used) to jobs
> as they consume it.
> HTH,
> Virginia Joseph
> ISO 9001:2008 / AS 9100 Rev. B:2004 / ISO 13485:2003
> 440-543-8157
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> <mailto:vantage%40yahoogroups.com>, Scott Kaufman
> <skaufman@<mailto:skaufman@>> wrote:
> > Everything is lot tracked by item. I will have 4 different raw
> material part numbers going into the finished product. Sometime multiple
> lots of the same part number.
> > Our finished product is also lot tracked.
> <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com
> <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>]
> On Behalf Of mmcwilliams22
> > Sent: Tuesday, July 05, 2011 9:46 AM
> Traceability
> > How many different raw materials go into a Job or Part?
> > Do you lot track?
> <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>,
> "scottyk537" <skaufman@<mailto:skaufman@>> wrote:
> > > We are going through our Implementation process with 9.05.604A.
> > > We have several 24/7 operations that require full raw material
> traceability. In a 24 hour period, we can produce 15 products. Our
> customer requires that we provide them with the raw materials that went
> into produce each product. Talking with our consultants, they suggest we
> have a new job for every product produced or use the split job feature.
> We are leaning away from the split job for several reasons.
> > > Does anyone have a better suggestion? If different jobs are the only
> way to go, is there an easy way to create these jobs on the fly so our
> manufacturing staff can do it?
> > > Any suggestions would help.
> > > Scott
> > <html>
> > <BR>
> > <font size="1", color="#000000", face="Arial, Helvetica, sans-serif">
> > CONFIDENTIALITY: The information contained in this email message,
> including any attachment(s),
> > may be privileged and confidential and protected from disclosure. The
> email is not intended for
> > transmission to, or receipt by, any unauthorized persons. If the
> reader of this message is not
> > the intended recipient, or an employee or agent responsible for
> delivering this message to the
> > intended recipient, you are hereby notified that any dissemination,
> distribution, or copying of
> > this communication or use of the information contained herein is
> strictly prohibited. If you have
> > received this electronic mail transmission in error, please delete it
> from your system without
> > copying or disseminating, and notify the sender by Reply email, so
> that our address record can be
> > corrected.
> > </font>
> > </html>
> <html>
> <BR>
> transmission to, or receipt by, any unauthorized persons. If the reader
> copying or disseminating, and notify the sender by Reply email, so that
> corrected.
> </font>
> </html>
We have several 24/7 operations that require full raw material traceability. In a 24 hour period, we can produce 15 products. Our customer requires that we provide them with the raw materials that went into produce each product. Talking with our consultants, they suggest we have a new job for every product produced or use the split job feature. We are leaning away from the split job for several reasons.
Does anyone have a better suggestion? If different jobs are the only way to go, is there an easy way to create these jobs on the fly so our manufacturing staff can do it?
Scott
Do you lot track?
> Scott
Everything is lot tracked by item. I will have 4 different raw material part numbers going into the finished product. Sometime multiple lots of the same part number.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of mmcwilliams22
Subject: [Vantage] Re: Large Blanket Jobs with Full Raw Material Traceability
Do you lot track?
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "scottyk537" <skaufman@...<mailto:skaufman@...>> wrote:
> Scott
<html>
<BR>
CONFIDENTIALITY: The information contained in this email message, including any attachment(s),
may be privileged and confidential and protected from disclosure. The email is not intended for
transmission to, or receipt by, any unauthorized persons. If the reader of this message is not
the intended recipient, or an employee or agent responsible for delivering this message to the
intended recipient, you are hereby notified that any dissemination, distribution, or copying of
this communication or use of the information contained herein is strictly prohibited. If you have
received this electronic mail transmission in error, please delete it from your system without
copying or disseminating, and notify the sender by Reply email, so that our address record can be
corrected.
</font>
</html>
Have you looked into using Serial Numbers? This would allow you to assign serial numbers to all raw materials when you receive them to inventory and specify which serial numbers are issued to jobs to satisfy material requirements. You can then assign serial numbers to the finished product when you receive them to inventory. When you ship to your customer from inventory, you can select which serialized parts you are shipping and the serial numbers would print on the packing slip. I think this would give you the traceability you need from customer shipment back to raw materils. Since you are a 24/7 operation, if you want your machinists to issue material to the jobs as they consume it, you can implement AMM and using MES the machinists can issue material from inventory (specifying which serail numbers are being used) to jobs as they consume it.
HTH,
Virginia Joseph
440-543-8157
> Do you lot track?
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "scottyk537" <skaufman@<mailto:skaufman@>> wrote:
> > Scott
> <html>
> <BR>
> corrected.
> </font>
> </html>
Thanks Virginia,
We might add 150gm of one lot and 300gm of another lot to produce 3000 cards(finished product) that has its own unique lot. These quantities would vary between runs.
Scott
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Virginia Joseph
HTH,
Virginia Joseph
440-543-8157
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Scott Kaufman <skaufman@...<mailto:skaufman@...>> wrote:
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of mmcwilliams22
> Do you lot track?
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, "scottyk537" <skaufman@<mailto:skaufman@>> wrote:
> > Scott
> <html>
> <BR>
> corrected.
> </font>
> </html>
<html>
<BR>
corrected.
</font>
</html>
Manasa
630.806.2000 x1515
Of Scott Kaufman
Traceability
Thanks Virginia,
Scott
Traceability
as they consume it.
HTH,
Virginia Joseph
440-543-8157
Traceability
> Do you lot track?
> > Scott
> <html>
> <BR>
> corrected.
> </font>
> </html>
<html>
<BR>
corrected.
</font>
</html>
