For those that have copier leases to renew (or current ones that can be
upgraded) Canon makes a copier that you can send to a Password and select
which drawer to print to from your computer. (Canon Imagerunner 550,
although I'm sure the industry does others) You then go to the copier to
enter password...then put your checks in the drawer you sent your print job
to. Works for us.
Sent: Friday, September 01, 2000 6:50 AM
To: vantage@egroups.com
Subject: [Vantage] Re: Laser Printer Advise
-------------------------- eGroups Sponsor
Does your printer have a manual feed tray? If you put the checks in
the manual feed tray and designate the printer to take the paper
from
there you may eliminate problems with people printing on your
checks.
That's what we do and I have nver had any problems.
to. Works for us.
from
checks.
--- In vantage@egroups.com, "Ludwig, Rick" <RickL@m...> wrote:
> We use an HP LaserJet 5SiNX and use it to print A/P checks. The
only
> problem we have is that this is the main network printer and my
clerk needs
> to go around and tell everyone who prints to that printer to not
> before she adds the check stock so that she can print checks. It
causes a
> lot of problems if someone forgets before she prints and they
on the
> check stock. Because this fouls up the check order (check stock
is
> prenumbered and no longer will agree to the check register
report),
she must
> delete the entire check run and reselect invoices to be paid
(there
may be a
> way to prevent this from happening, but it seems to work for us
until we set
> her up with her own LaserJet). I would suggest that you use a
small
> LaserJet exclusively for printing checks, unless there is another
way to
> prevent other users from printing once the check stock has been
added to the
> printer.
> Rick Ludwig
> Corporate Controller
> Metal Spinners, Inc.
> > From: rgors[SMTP:rgors@o...]
> > Reply To: vantage@egroups.com
> > Sent: Thursday, August 31, 2000 1:54 PM
> > To: 'vantage@egroups.com'
> > Subject: [Vantage] Laser Printer Advise
> > Hey gang....
> > I'm asking my boss for a brand-spanking-new laser printer!! If
it is
> > approved, I would like to buy one that will work with the big
"V"
and
> > specifically to print vendor checks.
> > A) Is this possible? Do people actually print vantage checks
without
> > disaster or chronic aggravation syndrome?
> > B) I'm thinking of an HP 4050se "Workgroup Printer" with "True
1200 dpi
> > at full speed" and "Prints 17 ppm". Anyone using one on their
> > network?
> > Any input is truly appreciated!!!!
> > Rick
> > MIS
> > Osco
> > We no longer allow attachments to files. To access/share Report
Files,
> > please go to the following link:
http://www.egroups.com/files/vantage/
> > (Note: If this link does not work for you the first time you
try
it, go
> > to www.egroups.com, login and be sure to save your password,
choose My
> > Groups, choose Vantage, then choose Files. If you save the
password, the
> > link above will work the next time you try it.)
Files, please go to the following link:
(Note: If this link does not work for you the first time you try
it, go to www.egroups.com, login and be sure to save your password, choose
My Groups, choose Vantage, then choose Files. If you save the password, the
