Lot Tracking
Note sure if this will help:-
We also use lot tracking for many of our parts. Vantage doesn't have
the capability to auto-generate a next lot number, and having a
number of goods receiving operators meant that it was difficult to
decide what the next lot number would be. We would have to record it
off-system somewhere, and this was going to be a pain to manage.
I therefore added a button to the receipt entry form which calculates
a lot number based on a date and time code. In fact I use the
following format: "080627/45567". The first 6-digits are the year,
the month and the day, and the last 5 digits are the number of
seconds which elapsed since midnight. Hence lot numbers are specific
to the date and time the part was entered ( at a resolution of 1-
second ). Ok, we will have a problem if two people enter parts at
exactly the same time, but that has never happened yet :o)
Therefore when the goods receiving operator enters the next part,
they click my "Get Lot Number" button, and the next lot number is
generated and stored in the field.
We find this works pretty well...
I hope this helps!
Nick Taylor
--- In vantage@yahoogroups.com, "eltaria.foong" <eltaria.foong@...>
wrote:
> Hi, I've been thinking about Lot Tracking in Vantage too.
> Someone mentioned they use Job Number as lot number, let's say i
have
> a Job 000090 which runs for a month, during the course of the
> production, I've received 2 different lot of the same materials,
lot A
> 56,000 and lot B 44,000.
> If I saved the finished good under Lot 000090, and 1 month down the
> road the supplier called and said Lot A is problematic, seems like
> I'll have to recall the entire batch of 000090?
> How would we be able to best handle this then?
> I was thinking of using 000090-1, 000090-2, 000090-3 and so on until
> the last run.
> Of course, there may be a possibility that a part of the job will be
> taking in 2 lots of materials, but at least we would've kept it down
> to a minimum, instead of recalling the entire batch of 100,000 in
job
> 000090?
> --- In vantage@yahoogroups.com, "Manasa Reddy" <manasa@> wrote:
> > Each labor detail record has a unique number...maybe you can use
that
> > field on the shipment somehow as your traceability.
> > Something to look at maybe....?????
> > M. Manasa Reddy
> > manasa@
> > P: 630-806-2000
> > F: 630-806-2001
> > ________________________________
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
Behalf
> > Of Arnulfo Mora
> > Sent: Tuesday, November 13, 2007 10:45 AM
> > Subject: [Vantage] Re: Lot Tracking
> > What we are currently planning is to use MES to report quantities
in
> > the basket. When the operator finish a basket they will hit report
> > quantity in MES, print tag, and send it on to the next operation
or to
> > shipping. For ASN's, we are required to have a unique number on
each
> > shipment. With what we can currently tell, we will not be able to
put
> > a unique number on the shipping tag for traceability. This is a
> > requirement for many automotive companies. This unique number is
used
> > to track back to the exact time, date, steel coil, operator, etc.
when
> > a customer calls in with a concern/rejection. We would use the
serial
> > number for containment of all baskets created under a certain
steel
> > tag number, after a certain number of hits, or any other items
that
> > may be suspect. The unique number is the trigger for all
> > correspondence with our customer. In essence, we need to serialize
> > every container (basket), but not every part. If you have any
> > additional questions, please let me know.
> > Thanks in Advance,
> > Eric
> > --- In vantage@yahoogroups.com <mailto:vantage%
40yahoogroups.com> ,
> > "Michael McWilliams"
> > <mmcwilliams22@> wrote:
> > > Right now they are in Numeric fields. Every receipt line is a
> > > new "Lot" basically serial but not exactly. That number is
generated
> > > by getting the next number from a UD table & creating a
> > > corresponding UD record. It then takes the numbers that you
entered
> > > and pushes them into the UD table. I am working on a
verification
> > > that will only allow you to enter if the properties are within
> > > acceptable values.
> > > We are required to have a "Bundle" number on our shipping tags.
> > > Every bundle gets a unique number. Since you are creating
baskets
> > > of parts I do not belive that the Vantage serialization will
work.
> > > It wants you to give a uniqe number to every unit that is
created.
> > > I have a question about your creation of baskets. Do you use
MES to
> > > do this or will it be done in the office?
> > "Arnulfo Mora" <amora@> wrote:
> > > > Mr. McWilliams,
> > > > How are you entering all of the Physical and Chemical
properties
> > > into
> > > > Vantage? Are you just dumping the information into a text
field,
> > > or
> > > > are you taking that information and verifying it against a
material
> > > > specification? Also, are you required to have a serial number
on
> > > your
> > > > shipping tags? We are currently implementing Vantage and are
> > > looking
> > > > for a way to use a serial number to track individual baskets
of
> > > parts
> > > > shipped to our customer. The serial number would be a self
> > > > populating, unique, sequential number. Thanks for any
information
> > > in
> > > > advance.
> > > > Eric
Lot Tracking is a very good tool for keeping a record of daily or "runs" of
production for Items or groups of items that need to be tracked for a
multiple of reasons. Lot Tracking is a manual tracking method and is not
designed for generating a unique number for each item. If you are in need
of uniquely identifying each item made take a look at serial numbers.
Serial numbers are a great way to guarantee that every item produced has its
own identification that you can access at any time now and in the future.
There IS more work involved by using them but in many cases well worth the
extra effort. Ask your CAM or call me for more information if you are
interested.
Thank you,
Kevin Kadamus
Senior Consultant
Epicor Authorized Partner
kkadamus@...
952-905-0387
CONFIDENTIALITY NOTICE: This electronic email transmission may contain
consultant/client privilege and confidential information intended only for
the individual or entity named above. Any dissemination, use, distribution,
copying or disclosure of this communication by any other person or entity is
strictly prohibited. Should you receive this transmission in error, please
notify the sender by telephone at 952-905-0387.
_____
nmtaylor1969
Sent: Friday, June 27, 2008 4:18 AM
I hope this helps!
Nick Taylor
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com,
have
lot A
> the last run.
job
> 000090?
that
> > M. Manasa Reddy
> > manasa@
> > P: 630-806-2000
> > F: 630-806-2001
> > From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
> > Of Arnulfo Mora
> > To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
in
or to
each
put
used
when
serial
steel
that
> > Thanks in Advance,
> > Eric
<mailto:vantage%
generated
entered
verification
> > > acceptable values.
baskets
work.
created.
MES to
<mailto:vantage%
> > > > Mr. McWilliams,
properties
> > > into
field,
> > > or
material
on
> > > your
> > > looking
of
> > > parts
information
> > > in
> > > > advance.
> > > > Eric
I agree with your comments. Just to remove any ambiguity, we use
serial number tracking for all appropriate manufactured parts that we
make in-house, and we use lot-tracking for material receipts coming
in from vendors. Currently every receipt line will get a different
lot number, but I guess in reality we could probably make a lot
number apply to all lines on a specific receipt. ( I haven't tried
this, so I dont know if Vahtage will allow different parts to exist
within one lot ). We merely wish to know where any given part came
from in the event we have a field failure etc. A lot number based on
a date and time code works well in our particular application.
or "runs" of
a
is not
in need
numbers.
produced has its
future.
worth the
are
> interested.
> Thank you,
> Kevin Kadamus
> Senior Consultant
> kkadamus@...
> 952-905-0387
contain
only for
distribution,
entity is
please
> _____
Behalf Of
> nmtaylor1969
have
it
calculates
specific
> I hope this helps!
> Nick Taylor
> "eltaria.foong" <eltaria.foong@>
> have
> lot A
the
until
> > the last run.
be
down
> job
> > 000090?
use
> that
> > > M. Manasa Reddy
> > > manasa@
> > > P: 630-806-2000
> > > F: 630-806-2001
> Behalf
> > > Of Arnulfo Mora
quantities
> in
report
operation
> or to
> each
to
> put
is
> used
etc.
> when
> serial
> steel
> that
serialize
> > > Thanks in Advance,
> > > Eric
> <mailto:vantage%
> generated
> entered
> verification
within
> > > > acceptable values.
tags.
> baskets
> work.
> created.
> MES to
> <mailto:vantage%
> > > > > Mr. McWilliams,
> properties
> > > > into
> field,
> > > > or
> material
number
> on
> > > > your
are
> > > > looking
baskets
> of
> > > > parts
> information
> > > > in
> > > > > advance.
> > > > > Eric
Nick,
Your Date/Timestamp lot numbering is an excellent idea that I would like to use as we implement Vantage here. Would you be willing to share your code for your Receipt Entry button to generate your Lot numbers?
Ed
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of nmtaylor1969
Sent: Saturday, June 28, 2008 1:38 AM
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Kevin Kadamus" <kkadamus@...> wrote:
or "runs" of
a
is not
in need
numbers.
produced has its
future.
worth the
are
> interested.
> Thank you,
> Kevin Kadamus
> Senior Consultant
> kkadamus@...
> 952-905-0387
contain
only for
distribution,
entity is
please
> _____
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On
Behalf Of
> nmtaylor1969
have
it
calculates
specific
> I hope this helps!
> Nick Taylor
> have
> lot A
the
until
> > the last run.
be
down
> job
> > 000090?
use
> that
> > > M. Manasa Reddy
> > > manasa@
> > > P: 630-806-2000
> > > F: 630-806-2001
> Behalf
> > > Of Arnulfo Mora
quantities
> in
report
operation
> or to
> each
to
> put
is
> used
etc.
> when
> serial
> steel
> that
serialize
> > > Thanks in Advance,
> > > Eric
> <mailto:vantage%
> generated
> entered
> verification
within
> > > > acceptable values.
tags.
> baskets
> work.
> created.
> MES to
> <mailto:vantage%
> > > > > Mr. McWilliams,
> properties
> > > > into
> field,
> > > > or
> material
number
> on
> > > > your
are
> > > > looking
baskets
> of
> > > > parts
> information
> > > > in
> > > > > advance.
> > > > > Eric
The information contained in this message is intended solely for the individual to whom it is specifically and originally addressed. This message and its contents may contain confidential or privileged information. If you are not the intended recipient, you are hereby notified that any disclosure or distribution, or taking any action in reliance on the contents of this information, is strictly prohibited.
We have taken precautions to minimize the risk of transmitting software viruses, but we advise you to carry out your own virus checks on any attachment to this message. We cannot accept liability for any loss or damage caused by software viruses.
This message (including any attachments) is intended only for
the use of the individual or entity to which it is addressed and
may contain information that is non-public, proprietary,
privileged, confidential, and exempt from disclosure under
applicable law or may constitute as attorney work product.
that any use, dissemination, distribution, or copying of this
communication is strictly prohibited. If you have received this
communication in error, notify us immediately by telephone and
(i) destroy this message if a facsimile or (ii) delete this message
immediately if this is an electronic communication.
Thank you.
Ok Ed, here you go...
I am assuming you are ok with the basic customisation stuff. You will
need to add a new command button into the "Stock" tab which is going
to replace the existing "Get Lot Receipt" button. You will need to
move the x,y location of the old button off screen somewhere as
making it invisible doesn't work. It just comes back to haunt you
when you run the form for real :o(
Into the click() event code of your new button you will need the
following code:-
Dim edvStockDtl As EpiDataView = CType(oTrans.EpiDataViews
("StockDtl"), EpiDataView)
if not edvStockDtl.HasRow then exit sub
edvStockDtl.dataView(edvStockDtl.Row).BeginEdit()
edvStockDtl.dataView(edvStockDtl.Row)("LotNum") = format
(datetime.now,"yyMMdd") + "/" + format
(Date.Now.TimeOfDay.TotalSeconds,"00000" ).ToString()
edvStockDtl.dataView(edvStockDtl.Row).EndEdit()
oTrans.NotifyAll()
This will handle the receipt of inventory items. If you want to lot
trace your buy direct stuff you will need to add a similar button to
the "Job Material" tab. This time however you will need to reference
the JobMtlDtl data view and not the StockDtl data view.
I played around with having a single method to create the lot number
and just call this from each button ( for example you might need a
3rd button for sub-contract material ), but I hit problems. As I was
under pressure to get something working I left the code alone and
just had three buttons each generating the lot number string. This
works fine.
I used this methodology in a previous system which has run for the
last 20-years. Unless 2 or more operators hit the button at exactly
the same second in the same day you will get unique lot numbers. It
works well for us.
Have fun :o)
Nick
--- In vantage@yahoogroups.com, Ed Garbowski <egarbowski@...> wrote:
> Nick,
numbers?
> Thanks,
> Ed
we
> or "runs" of
for
> a
> is not
> in need
> numbers.
> produced has its
> future.
> worth the
> are
> > interested.
> > Thank you,
> > Kevin Kadamus
> > Senior Consultant
> > kkadamus@
> > 952-905-0387
> contain
> only for
> distribution,
> entity is
error,
> please
> > _____
> Behalf Of
> > nmtaylor1969
> have
> it
> calculates
> specific
> > I hope this helps!
> > Nick Taylor
> > have
> > lot A
> the
like
> until
> > > the last run.
will
> be
> down
in
> > job
> > > 000090?
> use
> > that
> > > > M. Manasa Reddy
> > > > manasa@
> > > > P: 630-806-2000
> > > > F: 630-806-2001
> > Behalf
> > > > Of Arnulfo Mora
> quantities
> > in
> report
> operation
> > or to
on
> > each
> to
> > put
a
> is
> > used
> etc.
> > when
> > serial
> > steel
> > that
> serialize
> > > > Thanks in Advance,
> > > > Eric
> > <mailto:vantage%
a
> > generated
> > entered
> > verification
> within
> > > > > acceptable values.
> tags.
> > baskets
> > work.
> > created.
> > MES to
> > <mailto:vantage%
> > > > > > Mr. McWilliams,
> > properties
> > > > > into
> > field,
> > > > > or
> > material
> number
> > on
> > > > > your
> are
> > > > > looking
> baskets
> > of
> > > > > parts
> > information
> > > > > in
> > > > > > advance.
> > > > > > Eric
> Thank you.
Ed,
We have discovered a bug in the code I sent you ( typical! ), and I
am currently investigating the problem.
I think the call to oTrans.NotifyAll() is causing the record pointer
to move by accident. I believe this is resulting in the wrong parts
being receipted on some occasions by our operators.
Rob, perhaps your knowledge may be able to assist ?
I notice from the object explorer that this method can be called in
two ways:-
oTrans.NotifyAll(BruteForce) Scary or what!?
oTrans.NotifyAll(type, view)
I am hoping that the latter restricts the refresh to the current
dataview and might stop the record pointer from moving. Its a stab in
the dark, but I might be right...
The "type" parameter is described as:
Epicor.Mfg.UI.FrameWork.EpiTransaction+NotifyType
My skills are not good enough for me to deduce what this parameter
is. Would you happen to know ?
I have sent an e-mail to Epicor support, but sometimes this can be a
much faster medium. Any help would be gratefully received.
Nick
> Nick,
numbers?
> Thanks,
> Ed
we
> or "runs" of
for
> a
> is not
> in need
> numbers.
> produced has its
> future.
> worth the
> are
> > interested.
> > Thank you,
> > Kevin Kadamus
> > Senior Consultant
> > kkadamus@
> > 952-905-0387
> contain
> only for
> distribution,
> entity is
error,
> please
> > _____
> Behalf Of
> > nmtaylor1969
> have
> it
> calculates
> specific
> > I hope this helps!
> > Nick Taylor
> > have
> > lot A
> the
like
> until
> > > the last run.
will
> be
> down
in
> > job
> > > 000090?
> use
> > that
> > > > M. Manasa Reddy
> > > > manasa@
> > > > P: 630-806-2000
> > > > F: 630-806-2001
> > Behalf
> > > > Of Arnulfo Mora
> quantities
> > in
> report
> operation
> > or to
on
> > each
> to
> > put
a
> is
> > used
> etc.
> > when
> > serial
> > steel
> > that
> serialize
> > > > Thanks in Advance,
> > > > Eric
> > <mailto:vantage%
a
> > generated
> > entered
> > verification
> within
> > > > > acceptable values.
> tags.
> > baskets
> > work.
> > created.
> > MES to
> > <mailto:vantage%
> > > > > > Mr. McWilliams,
> > properties
> > > > > into
> > field,
> > > > > or
> > material
> number
> > on
> > > > > your
> are
> > > > > looking
> baskets
> > of
> > > > > parts
> > information
> > > > > in
> > > > > > advance.
> > > > > > Eric
> Thank you.
Nick,
NotifyAll is excessive, use Notify instead try:
YourDataView.Notify(New EpiNotifyArgs(FormName,
yourDataView.Row, yourDataview.Column))
Regards,
Stephen
Of nmtaylor1969
Sent: 14 July 2008 13:06
Subject: [Vantage] Re: Lot Tracking / Rob Can You Help ?!
Ed,
two ways:-
Nick
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Ed
> Nick,
numbers?
> Thanks,
> Ed
we
<mailto:vantage%
> or "runs" of
for
> a
> is not
> in need
> numbers.
> produced has its
> future.
> worth the
> are
> > interested.
> > Thank you,
> > Kevin Kadamus
> > Senior Consultant
> > kkadamus@
> > 952-905-0387
> contain
> only for
> distribution,
> entity is
error,
> please
> > _____
> Behalf Of
> > nmtaylor1969
> have
> it
> calculates
> specific
> > I hope this helps!
> > Nick Taylor
> > have
> > lot A
> the
like
> until
> > > the last run.
will
> be
> down
in
> > job
> > > 000090?
> use
> > that
> > > > M. Manasa Reddy
> > > > manasa@
> > > > P: 630-806-2000
> > > > F: 630-806-2001
> > Behalf
> > > > Of Arnulfo Mora
> quantities
> > in
> report
> operation
> > or to
on
> > each
> to
> > put
a
> is
> > used
> etc.
> > when
> > serial
> > steel
> > that
> serialize
> > > > Thanks in Advance,
> > > > Eric
> > <mailto:vantage%
a
> > generated
> > entered
> > verification
> within
> > > > > acceptable values.
> tags.
> > baskets
> > work.
> > created.
> > MES to
> > <mailto:vantage%
> > > > > > Mr. McWilliams,
> > properties
> > > > > into
> > field,
> > > > > or
> > material
> number
> > on
> > > > > your
> are
> > > > > looking
> baskets
> > of
> > > > > parts
> > information
> > > > > in
> > > > > > advance.
> > > > > > Eric
> Thank you.
Many thanks Stephen...
However I am not clear on the command syntax. Is there anywhere
within the object browser that I can find out what EpiNotifyArgs
should consist of ?
My dataview is called: edvStockDtl and the field in question is
LotNum.
Any help with the correct syntax would be greatly appreciated...
Best regards,
Nick
--- In vantage@yahoogroups.com, "Stephen Edginton" <stephene@...>
wrote:
> Nick,
> Regards,
> Stephen
Behalf
> Of nmtaylor1969
> Ed,
pointer
> two ways:-
in
a
> Thanks,
> Nick
Ed
> Garbowski <egarbowski@> wrote:
> > Nick,
willing
Lot
> numbers?
> > Thanks,
> > Ed
that
> we
coming
exist
on
> <mailto:vantage%
> > or "runs" of
> for
> > a
and
> > is not
are
> > in need
> > numbers.
> > produced has its
the
> > future.
> > worth the
you
> > are
> > > interested.
> > > Thank you,
> > > Kevin Kadamus
> > > Senior Consultant
> > > kkadamus@
> > > 952-905-0387
> > contain
intended
> > only for
> > distribution,
or
> > entity is
> error,
> > please
> > > _____
> > Behalf Of
> > > nmtaylor1969
> > have
to
record
> > it
> > calculates
year,
> > specific
1-
at
part,
is
> > > I hope this helps!
> > > Nick Taylor
say i
> > > have
materials,
> > > lot A
down
> > the
> like
> > until
> > > > the last run.
> will
> > be
it
> > down
100,000
> in
> > > job
> > > > 000090?
> > use
> > > that
> > > > > M. Manasa Reddy
> > > > > manasa@
> > > > > P: 630-806-2000
> > > > > F: 630-806-2001
> > > Behalf
> > > > > Of Arnulfo Mora
> > quantities
> > > in
> > report
> > operation
> > > or to
number
> on
> > > each
able
> > to
> > > put
is
> a
number
> > is
> > > used
> > etc.
> > > when
the
> > > serial
certain
> > > steel
items
> > > that
> > serialize
any
> > > > > Thanks in Advance,
> > > > > Eric
> > > <mailto:vantage%
is
> a
> > > generated
you
> > > entered
> > > verification
> > within
> > > > > > acceptable values.
> > tags.
> > > baskets
will
> > > work.
> > > created.
use
> > > MES to
> > > <mailto:vantage%
> > > > > > > Mr. McWilliams,
> > > properties
> > > > > > into
text
> > > field,
> > > > > > or
against a
> > > material
> > number
> > > on
> > > > > > your
> > are
> > > > > > looking
> > baskets
> > > of
> > > > > > parts
self
> > > information
> > > > > > in
> > > > > > > advance.
> > > > > > > Eric
privileged
in
prohibited.
liability
message
> > Thank you.
Try a Application.DoEvents() before the notify. I have fixed (or found a workaround for) some NotifyAll() problems by using that before the call to NotifyAll().
Kunal
----- Original Message ----
Sent: Monday, July 14, 2008 7:06:01 AM
Ed,
I think the call to oTrans.NotifyAll( ) is causing the record pointer
two ways:-
oTrans.NotifyAll( BruteForce) Scary or what!?
oTrans.NotifyAll( type, view)
Epicor.Mfg.UI. FrameWork. EpiTransaction+ NotifyType
Nick
--- In vantage@yahoogroups .com, Ed Garbowski <egarbowski@ ...> wrote:
> Nick,
numbers?
> Thanks,
> Ed
> ____________ _________ _________ __
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
> To: vantage@yahoogroups .com
we
> --- In vantage@yahoogroups .com<mailto:vantage%
> or "runs" of
for
> a
> is not
> in need
> numbers.
> produced has its
> future.
> worth the
> are
> > interested.
> > Thank you,
> > Kevin Kadamus
> > Senior Consultant
> > kkadamus@
> > 952-905-0387
> contain
> only for
> distribution,
> entity is
error,
> please
> > _____
> > From: vantage@yahoogroups .com<mailto:vantage% 40yahoogroups. com>
[mailto:vantage@yahoogroups .com<mailto:vantage% 40yahoogroups. com>] On
> Behalf Of
> > nmtaylor1969
> > To: vantage@yahoogroups .com<mailto:vantage% 40yahoogroups. com>
> have
> it
> calculates
> > following format: "080627/45567" . The first 6-digits are the year,
> specific
> > I hope this helps!
> > Nick Taylor
40yahoogroups. com> .com,
> > "eltaria.foong" <eltaria.foong@ >
> > have
> > lot A
> the
like
> until
> > > the last run.
will
> be
> down
in
> > job
> > > 000090?
> use
> > that
> > > > Something to look at maybe....??? ??
> > > > M. Manasa Reddy
> > > > manasa@
> > > > P: 630-806-2000
> > > > F: 630-806-2001
> > [mailto:vantage@ yahoogroups <mailto:vantage%
> 40yahoogroups. com> .com] On
> > Behalf
> > > > Of Arnulfo Mora
> quantities
> > in
> report
> operation
> > or to
on
> > each
> to
> > put
a
> is
> > used
> etc.
> > when
> > serial
> > steel
> > that
> serialize
> > > > Thanks in Advance,
> > > > Eric
> > <mailto:vantage%
> > 40yahoogroups. com> ,
a
> > generated
> > entered
> > verification
> within
> > > > > acceptable values.
> tags.
> > baskets
> > work.
> > created.
> > MES to
> > <mailto:vantage%
> > > > > > Mr. McWilliams,
> > properties
> > > > > into
> > field,
> > > > > or
> > material
> number
> > on
> > > > > your
> are
> > > > > looking
> baskets
> > of
> > > > > parts
> > information
> > > > > in
> > > > > > advance.
> > > > > > Eric
> Thank you.
You could try
edvStockDtl.Notify(new EpiNotifyArgs(formName,
edvStockDtl.Row,EpiTransaction.Initialize)
There are many constructors for the EpiNotifyArgs
Of nmtaylor1969
Sent: 14 July 2008 14:17
should consist of ?
LotNum.
Best regards,
Nick
wrote:
> Nick,
> Regards,
> Stephen
Behalf
> Of nmtaylor1969
> Ed,
pointer
> two ways:-
in
a
> Thanks,
> Nick
Ed
> > Nick,
willing
Lot
> numbers?
> > Thanks,
> > Ed
<mailto:vantage%
that
> we
coming
exist
on
> <mailto:vantage%
> > or "runs" of
> for
> > a
and
> > is not
are
> > in need
> > numbers.
> > produced has its
the
> > future.
> > worth the
you
> > are
> > > interested.
> > > Thank you,
> > > Kevin Kadamus
> > > Senior Consultant
> > > kkadamus@
> > > 952-905-0387
> > contain
intended
> > only for
> > distribution,
or
> > entity is
> error,
> > please
> > > _____
> > Behalf Of
> > > nmtaylor1969
> > have
to
record
> > it
> > calculates
year,
> > specific
1-
at
part,
is
> > > I hope this helps!
> > > Nick Taylor
say i
> > > have
materials,
> > > lot A
down
> > the
> like
> > until
> > > > the last run.
> will
> > be
it
> > down
100,000
> in
> > > job
> > > > 000090?
> > use
> > > that
> > > > > M. Manasa Reddy
> > > > > manasa@
> > > > > P: 630-806-2000
> > > > > F: 630-806-2001
> > > Behalf
> > > > > Of Arnulfo Mora
> > quantities
> > > in
> > report
> > operation
> > > or to
number
> on
> > > each
able
> > to
> > > put
is
> a
number
> > is
> > > used
> > etc.
> > > when
the
> > > serial
certain
> > > steel
items
> > > that
> > serialize
any
> > > > > Thanks in Advance,
> > > > > Eric
> > > <mailto:vantage%
is
> a
> > > generated
you
> > > entered
> > > verification
> > within
> > > > > > acceptable values.
> > tags.
> > > baskets
will
> > > work.
> > > created.
use
> > > MES to
> > > <mailto:vantage%
> > > > > > > Mr. McWilliams,
> > > properties
> > > > > > into
text
> > > field,
> > > > > > or
against a
> > > material
> > number
> > > on
> > > > > > your
> > are
> > > > > > looking
> > baskets
> > > of
> > > > > > parts
self
> > > information
> > > > > > in
> > > > > > > advance.
> > > > > > > Eric
privileged
in
prohibited.
liability
message
> > Thank you.
Sorry - Never have tried use of it. (You put it well - too scary!)
Maybe Mark W?
Rob
Date: Monday, July 14, 2008, 8:06 AM
Ed,
two ways:-
Nick
> Nick,
numbers?
> Thanks,
> Ed
we
> or "runs" of
for
> a
> is not
> in need
> numbers.
> produced has its
> future.
> worth the
> are
> > interested.
> > Thank you,
> > Kevin Kadamus
> > Senior Consultant
> > kkadamus@
> > 952-905-0387
> contain
> only for
> distribution,
> entity is
error,
> please
> > _____
> Behalf Of
> > nmtaylor1969
> have
> it
> calculates
> specific
> > I hope this helps!
> > Nick Taylor
> > have
> > lot A
> the
like
> until
> > > the last run.
will
> be
> down
in
> > job
> > > 000090?
> use
> > that
> > > > M. Manasa Reddy
> > > > manasa@
> > > > P: 630-806-2000
> > > > F: 630-806-2001
> > Behalf
> > > > Of Arnulfo Mora
> quantities
> > in
> report
> operation
> > or to
on
> > each
> to
> > put
a
> is
> > used
> etc.
> > when
> > serial
> > steel
> > that
> serialize
> > > > Thanks in Advance,
> > > > Eric
> > <mailto:vantage%
a
> > generated
> > entered
> > verification
> within
> > > > > acceptable values.
> tags.
> > baskets
> > work.
> > created.
> > MES to
> > <mailto:vantage%
> > > > > > Mr. McWilliams,
> > properties
> > > > > into
> > field,
> > > > > or
> > material
> number
> > on
> > > > > your
> are
> > > > > looking
> baskets
> > of
> > > > > parts
> > information
> > > > > in
> > > > > > advance.
> > > > > > Eric
> Thank you.
> Maybe Mark W?
When it comes to serious VB customization, I defer to Steve E. or Bernie W.
Separately, I figured that since Epicor took a lot of trouble to separate
the user interface from the business rules that I would try to put business
logic into BPMs instead of user interface.
But since you're asking for this on a click event, I wonder if it's possible
to fire a BPM event from a button and have that code update the lot field?
Mark W.
Neat idea Mark... Trap the BO method called when the (presumably native)button is clicked?
Rob
--- On Mon, 7/14/08, Mark Wonsil <mark_wonsil@...> wrote:
Subject: RE: [Vantage] Re: Lot Tracking / Rob Can You Help ?!
Date: Monday, July 14, 2008, 5:17 PM
> Maybe Mark W?
Mark W.
Ed,
The magic line of code in the lot tracking code snippet is:
edvStockDtl.Notify( New EpiNotifyArgs(oTrans.EpiBaseForm,
edvStockDtl.Row, EpiTransaction.NotifyType.Initialize ))
This should replace the oTrans.NotifyAll() method call. You will need
change the dataview name as required.
You should find the lot tracking code now works fine. ;o)
Thanks to Epicor for helping me out with this...
Nick
> Nick,
numbers?
> Thanks,
> Ed
we
> or "runs" of
for
> a
> is not
> in need
> numbers.
> produced has its
> future.
> worth the
> are
> > interested.
> > Thank you,
> > Kevin Kadamus
> > Senior Consultant
> > kkadamus@
> > 952-905-0387
> contain
> only for
> distribution,
> entity is
error,
> please
> > _____
> Behalf Of
> > nmtaylor1969
> have
> it
> calculates
> specific
> > I hope this helps!
> > Nick Taylor
> > have
> > lot A
> the
like
> until
> > > the last run.
will
> be
> down
in
> > job
> > > 000090?
> use
> > that
> > > > M. Manasa Reddy
> > > > manasa@
> > > > P: 630-806-2000
> > > > F: 630-806-2001
> > Behalf
> > > > Of Arnulfo Mora
> quantities
> > in
> report
> operation
> > or to
on
> > each
> to
> > put
a
> is
> > used
> etc.
> > when
> > serial
> > steel
> > that
> serialize
> > > > Thanks in Advance,
> > > > Eric
> > <mailto:vantage%
a
> > generated
> > entered
> > verification
> within
> > > > > acceptable values.
> tags.
> > baskets
> > work.
> > created.
> > MES to
> > <mailto:vantage%
> > > > > > Mr. McWilliams,
> > properties
> > > > > into
> > field,
> > > > > or
> > material
> number
> > on
> > > > > your
> are
> > > > > looking
> baskets
> > of
> > > > > parts
> > information
> > > > > in
> > > > > > advance.
> > > > > > Eric
> Thank you.
Thanks for the code and the 'beau cous' of time that you saved me in trying to make this work myself. Greatly appreciated!
Ed
Sent: Friday, July 18, 2008 7:23 AM
Ed,
Nick
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Ed Garbowski <egarbowski@...> wrote:
> Nick,
numbers?
> Thanks,
> Ed
we
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%
> or "runs" of
for
> a
> is not
> in need
> numbers.
> produced has its
> future.
> worth the
> are
> > interested.
> > Thank you,
> > Kevin Kadamus
> > Senior Consultant
> > kkadamus@
> > 952-905-0387
> contain
> only for
> distribution,
> entity is
error,
> please
> > _____
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On
> Behalf Of
> > nmtaylor1969
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> have
> it
> calculates
> specific
> > I hope this helps!
> > Nick Taylor
> > have
> > lot A
> the
like
> until
> > > the last run.
will
> be
> down
in
> > job
> > > 000090?
> use
> > that
> > > > M. Manasa Reddy
> > > > manasa@
> > > > P: 630-806-2000
> > > > F: 630-806-2001
> > Behalf
> > > > Of Arnulfo Mora
> quantities
> > in
> report
> operation
> > or to
on
> > each
> to
> > put
a
> is
> > used
> etc.
> > when
> > serial
> > steel
> > that
> serialize
> > > > Thanks in Advance,
> > > > Eric
> > <mailto:vantage%
a
> > generated
> > entered
> > verification
> within
> > > > > acceptable values.
> tags.
> > baskets
> > work.
> > created.
> > MES to
> > <mailto:vantage%
> > > > > > Mr. McWilliams,
> > properties
> > > > > into
> > field,
> > > > > or
> > material
> number
> > on
> > > > > your
> are
> > > > > looking
> baskets
> > of
> > > > > parts
> > information
> > > > > in
> > > > > > advance.
> > > > > > Eric
> Thank you.
Thank you.
I am new to Vantage 8.03.407 and we have a similar situation where we create 'Printed Rolls' which are then converted into 'Cases' of 'Bags' and the 'Cases' are then created into a 'Pallet' and the PalletID is our unique container id that we need for shipping. I came across your message in this group and I wanted to reach out to see how did you eventually accomplish this. If you would be so kind as to possibly share your findings it would be greatly appreciated. Our PM for implementation has not been able to address this very important issues for us yet.
> Ed
> Ed,
> Nick
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Ed Garbowski <egarbowski@> wrote:
> > Nick,
> numbers?
> > Thanks,
> > Ed
> we
> > or "runs" of
> for
> > a
> > is not
> > in need
> > numbers.
> > produced has its
> > future.
> > worth the
> > are
> > > interested.
> > > Thank you,
> > > Kevin Kadamus
> > > Senior Consultant
> > > kkadamus@
> > > 952-905-0387
> > contain
> > only for
> > distribution,
> > entity is
> error,
> > please
> > > _____
> > Behalf Of
> > > nmtaylor1969
> > have
> > it
> > calculates
> > specific
> > > I hope this helps!
> > > Nick Taylor
> > > have
> > > lot A
> > the
> like
> > until
> > > > the last run.
> will
> > be
> > down
> in
> > > job
> > > > 000090?
> > use
> > > that
> > > > > M. Manasa Reddy
> > > > > manasa@
> > > > > P: 630-806-2000
> > > > > F: 630-806-2001
> > > Behalf
> > > > > Of Arnulfo Mora
> > quantities
> > > in
> > report
> > operation
> > > or to
> on
> > > each
> > to
> > > put
> a
> > is
> > > used
> > etc.
> > > when
> > > serial
> > > steel
> > > that
> > serialize
> > > > > Thanks in Advance,
> > > > > Eric
> > > <mailto:vantage%
> a
> > > generated
> > > entered
> > > verification
> > within
> > > > > > acceptable values.
> > tags.
> > > baskets
> > > work.
> > > created.
> > > MES to
> > > <mailto:vantage%
> > > > > > > Mr. McWilliams,
> > > properties
> > > > > > into
> > > field,
> > > > > > or
> > > material
> > number
> > > on
> > > > > > your
> > are
> > > > > > looking
> > baskets
> > > of
> > > > > > parts
> > > information
> > > > > > in
> > > > > > > advance.
> > > > > > > Eric
> > Thank you.
> Thank you.
