MES - Return all rows for searches
In your MES config file set your <DefaultSearchPageSize value="10000" />Â or
higher number
Sent: Thu, July 22, 2010 6:39:29 PM
Subject: Re: [Vantage] MES - Return all rows for searches
Â
We're on 8 & this works on some search windows.
1. Hit search
2. Click options
3. Check return all rows & OK.
4. Right click within search window & if it offer a save settings option, do it.
That's a personalization so it would need to be done for all appropriate users.
You can try it in developer mode & see if at step 4 you can save it as a
customization & make it active for all users.
Last gasp method: Write a BAQ mimicing the job op search & set all fields to be
usable in searches. When in the search window, create a named search based on
the BAQ & make it the default. (Unfortunately - This to is personalization &
must be done for each user.)
Sure hope someone on 9 knows a better way (because this stuff stinks on 8 to
manage).
Rob
--- Original Message ---
Sent:Thu 7/22/10 5:05 pm
To:vantage@yahoogroups.com
Subj:[Vantage] MES - Return all rows for searches
EPICOR 9.04
Anyone know how to return all rows automatically in MES for searches such as Job
Search in Start Production Activity for all users?
Jeff Sanders
EPICOR 9.04
Anyone know how to return all rows automatically in MES for searches such as Job Search in Start Production Activity for all users?
Jeff Sanders
In the .mfgsys config file you're using for that icon set the
DefaultSearchPageSize to 0 I think if you want to return all rows.
-bws
Of jeffery_p_sanders
Sent: Thursday, July 22, 2010 4:30 PM
Subject: [Vantage] MES - Return all rows for searches
EPICOR 9.04
Jeff Sanders
1. Hit search
2. Click options
You can try it in developer mode & see if at step 4 you can save it as a customization & make it active for all users.
Last gasp method: Write a BAQ mimicing the job op search & set all fields to be usable in searches. When in the search window, create a named search based on the BAQ & make it the default. (Unfortunately - This to is personalization & must be done for each user.)
Sure hope someone on 9 knows a better way (because this stuff stinks on 8 to manage).
Rob
EPICOR 9.04
Jeff Sanders
