For what it's worth, you can just download crystal from the SAP site. There
isn't anything special about the version that comes with Epicor.
*John Driggers*
*Chief Data Wrangler*
*I have an Epicor blog <http://usdoingstuff.com/>. How useful is that?*
*:: 904.404.9233
:: waffqle@...
:: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
*John Driggers*
*:: 904.404.9233
:: waffqle@...
On Wed, Oct 24, 2012 at 4:57 AM, nustepvantage <dpfiester@...> wrote:
> I've heard through the grape vine that a 64-bit Crystal runtime will be
> released with the 701 service pack? Last I saw 701 was scheduled for
> release at the end of this month. Has anyone else heard this?
> Thanks,
> David Pfiester
> NuStep, Inc.
> --- In vantage@yahoogroups.com, "jgiese1988" <epicor-team@...> wrote:
> > We tried it just says invalid installation. Oh well if there is no real
> , general, use for the x64 version I won't worry about it too much.
> > --- In vantage@yahoogroups.com, "Lisser, Jennifer" <Jennifer.Lisser@>
> wrote:
> > > I don't believe there is a native 64-bit Crystal Reports 2008 Viewer.
> It's supported on 64-bit machines but only in 32-bit mode as far as I know.
> Epicor only supports the 2008 SP3 viewer officially. I had to upgrade to
> SP4 due to some problems with getting labels to print.
> > > You can always give it a try if you want to run Epicor 64-bit and see
> if the 32-bit version work. I haven't tested it, was only told it didn't
> work. If you test and find others please share :)
