MRP Planning Workbench Date Suggestion
Anyone have any suggestions or similar issues? Perhaps you could
just provide some input on how you handle Jobs with one Subcontract
Operation.
--- In vantage@yahoogroups.com, "Brian" <brian.chandler@...> wrote:
> We are trying to figure out an issue we have with MRP. Let assume
we
> have a sales order for 1000 of a part with a lead time of 30
days.
> The 30 day lead time was set by using a part class with the
Receive
> Field on the class set to 30. It is setup as Make to Stock with a
Min
> Lot size of 1000. In addition the Method has the Days Out set to
20
> days.
> We create a job to support this order with the following dates
> Req By: 05/28/2008
> Start: 03/19/2008
> Due: 04/16/2008
> The problem is that the suggestion gets created correctly the
first
> time we run MRP. The next time we run MRP w/Regenerative option
> selected it will create a suggestion to change the Due Date to
> 5/28/2008.
We are trying to figure out an issue we have with MRP. Let assume we
have a sales order for 1000 of a part with a lead time of 30 days.
The 30 day lead time was set by using a part class with the Receive
Field on the class set to 30. It is setup as Make to Stock with a Min
Lot size of 1000. In addition the Method has the Days Out set to 20
days.
Req By: 05/28/2008
Start: 03/19/2008
Due: 04/16/2008
The problem is that the suggestion gets created correctly the first
5/28/2008.
