Michelle,
Thanks. It seems we didn't have Sonic up and running. We may yet
encounter other issues, but this is the first brick wall to scale.
Llynn
--- In vantage@yahoogroups.com, "Michelle de la Vega" <mdelavega@...>
Llynn
wrote:
> First, Make sure that Sonic is running on your server for the multi
> company features to work.
> Second, it's possible you didn't mark in the multi-company configuration
> that you didn't select "send customer"...that would prevent you from
> selecting customers as global.
> Michelle de la Vega
> Business Applications Manager
> Cold Jet, LLC
> 455 Wards Corner Road
> Loveland, Ohio 45140
> 513-716-6400 (direct)
> 513-382-3281 (cell)
> 513-831-1209 (fax)
> www.coldjet.com
> Of Lynn Thomas 83
> Sent: Tuesday, May 20, 2008 10:05 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Multi-Company and Global settings
> We're on 8.305.403D. I'm trying to set up another company and set
> some of our parts and customers as Global, so we can use them there.
> I've activated the Multi-Company Server Process, and stopped and
> restarted the Process Server. After all that, nothing shows up when I
> look for parts in the receiving company.
> Separately, in the host company Customer Maintenance, the IC Trader
> checkbox is available but the Global checkbox is not. According to
> Help, both of these are only available if we're using External System
> Integration Tools. So, why would one be available and not the other?
> It's not a problem that I can only have one of these activated at a
> time, but I'd like to be able to choose _which_ one.
> Does anyone have any information or ideas that would shed light on
> either of these situations?
> Lynn Thomas
> Senior Engineer
> SAIC
> Indianapolis, IN
