Multiple Field Groups
IDC allows multiple Tables but how do I get this to load into ECM?
The Batch Import only lets me select one Field Group.
This took a while to figure out, but you need to use the pipe character |
For my keyboard, this is directly above my Enter key and is entered by using "Shift + " to get it working. Some things to note are that the Test Import option in the ECM Client likely will not show if this is configured correctly or not and you will need to import into ECM to validate. Furthermore, the field group name and fields need to be the EXACT same in IDC, the ECM Client and ECM, include case sensitivity and formats.
