I should also add that you can turn that functionality off... I have
created BPM's that do a better job for us of monitoring that anyhow..
Of alldoneprojects
Sent: Thursday, July 09, 2009 8:13 PM
Subject: [Vantage] Re: Negative warning when pack / ship reduces to zero
At least I know I'm not going bonkers now. Well, not becasue of that
anyway...
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Rob
Bucek" <rbucek@...> wrote:
Behalf
Of alldoneprojects
anyway...
>[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Ive seen that happen from time to time..its definitely a small
> exception, and thus far haven't been able to determine a root cause..
Behalf
> Of alldoneprojectszero
> Sent: Thursday, July 09, 2009 3:50 PM
>Oh
> We checked the bin that wasn't it and wasn't allocated anywhere else.
> well hope it doesn't happen again...<mailto:vantage%40yahoogroups.com> ,
> Michelle de la Vega <mdelavega@> wrote:only
> > You shouldn't get an error when you go to Zero in a specific bin
> when you go negative. That being said, if you have 20 in bin "A" andthe
> packing slip pulls 20 from bin "B" you will get the error because theyet.
> Bin is going negative.
> > Another possibility is that you have 20 on another packing slip for
> another order, you just haven't marked that packing slip "shipped"
> > I would use the Time Phase tracker to determine what is causing the
> error.
> > Michelle de la Vega
> > Business Applications Manager
> > Cold Jet, LLC
> > 455 Wards Corner Road
> > Loveland, Ohio 45140
> > USA
> > +1 513-716-6400 (office)
> > +1 513-382-3281 (mobile)
> > +1 513-831-1209 (fax)
> > www.coldjet.com<http://www.coldjet.com>
> > [cid:image001.jpg@]
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> ] On
> Behalf Of alldoneprojects<mailto:vantage%40yahoogroups.com>
> > Sent: Thursday, July 09, 2009 1:24 PM
> > Subject: [Vantage] Negative warning when pack / ship reduces to zero[Non-text portions of this message have been removed]
> > We get a warning that stock will go negative if something is shipped
> but in fact it will just put stock at zero. Is this normal or is there
> something I'm overlooking?
> > Regards,
> > -Ramsey
> > ramsey@<mailto:ramsey%40alldoneit.com>
