Yep it says SSRS only….
Work Station Method is blank and the Epicor SSRS Portal field is blank as well.
The SSRS Printer Option is set to Client and Server Printing.
Manasa
Sent: Wednesday, May 13, 2015 6:23 PM
Subject: [Vantage] RE: Restored db to test and now cannot find reports
Check out
System Setup / Company Maintenance
On the Email and Reporting Sheet, make sure the “Allowed Report Style” is correct for your environment. Not sure why a restore would change this but one more thing to check.
Mike
Sent: Wednesday, May 13, 2015 2:26 PM
I checked out the report style the path starts with ‘reports’….but when I restored last time I know did not have to change anything here….
M
Sent: Wednesday, May 13, 2015 3:12 PM
Is the Report Style pointing at the correct location of the report? The first chunk of the path is the DB name which (usually) gets followed by the last part (either SSRS or Crystal I think). I do all my report development in Test and when ready copy it to the corresponding folder in Pilot (later to be Live). But when the DB gets restored if the reports are not in the new DB specific location there might be an issue. That is the report style that got restored might no longer be valid for that DB. Just a first thought.
-Todd C.
Sent: Wednesday, May 13, 2015 1:28 PM
Subject: [Vantage] Restored db to test and now cannot find reports
I have no issues restoring my backup to my test environment, but for some reason when I try to print any of the forms it cannot find the report. But if I try to run an actual report there is no problem.
What could I be missing? The system agent path is fine. Now I have no idea what I did before to get this to work.
Any ideas are appreciated!
Manasa
IMPORTANT NOTICE FROM API: This communication, including any attachments, contains information that may be confidential or privileged and is intended solely for the entity or individual to whom it is addressed. If you are not the intended recipient, please contact the sender immediately and delete this message. Any unauthorized disclosure, copying or distribution of this message is strictly prohibited.
