Non-part numbered additions to Jobs
Was the job rescheduled after adding the material?
Liz
Sent: Wednesday, March 09, 2005 11:16 AM
Subject: RE: [Vantage] Non-part numbered additions to Jobs
Hi,
> When you add the items to the job as a material, is the
> 'Purchase Direct'
> flag checked off?
Yes, it was.
I _was_ thinking perhaps the 'Added Material' flag perhaps had something
to do with it, but it doesn't seem to correlate...
Duane
> From: Duane Kaufman [mailto:dkaufman@...]
> Sent: March 09, 2005 1:51 PM
> Hi,
> > If you are on 6.1, go to the master part, click on the
> > Inv/Purch button. In there are two flags, one to process MRP
> > and one to create PO Suggestions.
> Yes, I should have mentioned, I am using 6.1.
> That being said however, doesn't solve my problem. The items are _not_
> in the master BOM, so I can't set these flags. These flags
> _are_ set on
> the top-level part (the output for the job, which has been
> put into the
> parts master)
> As I said, some items show up in suggestions, while others do not.
> Thanks,
> Duane
> > M. Manasa Reddy
> > ERP Specialist
> > Crestview Aerospace Corporation
> > Email: mreddy@...
> > Phone: (850) 682-2746 x 272
> > Sent: Wednesday, March 09, 2005 12:18 PM
> > Subject: [Vantage] Non-part numbered additions to Jobs
> > Hi,
> > We just noticed that certain parts that were added to a job
> > (these parts
> > are _not_ part-numbered, or in our BOM) showed up in p.o.
> > suggestions,
> > while others did not.
> > What flag or setting do I need to set in order to have
> > suggestions pick
> > up these added items?
> > Thanks,
> > Duane
> > NOTICE: This communication may contain privileged or other
> > confidential information for the sole use of the designated
> > recipients. If you have received it in error, please advise
> > the sender by reply email and immediately delete the message
> > and any attachments without reviewing, copying or disclosing
> > the contents.
> > Useful links for the Yahoo!Groups Vantage Board are: (
> > Note: You must have already linked your email address to a
> > yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for
> > Report Builder and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/links
> > Yahoo! Groups Sponsor
> > ADVERTISEMENT
> > Yahoo! Groups Links
> > a.. To visit your group on the web, go to:
<http://groups.yahoo.com/group/vantage/>
> > b.. To unsubscribe from this group, send an email to:
> > vantage-unsubscribe@yahoogroups.com
> > c.. Your use of Yahoo! Groups is subject to the Yahoo!
> > Terms of Service.
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
> > You must have already linked your email address to a yahoo id
> > to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
> > goto: http://groups.yahoo.com/group/vantage/links
> > Yahoo! Groups Links
> You must have
> Builder and
> Yahoo! Groups Links
> to enable access. )
> Yahoo! Groups Links
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=1293o26av/M=298184.6018725.7038619.3001176/D=gr
oups/S=1705007183:HM/EXP=1110482124/A=2593423/R=0/SIG=11el9gslf/*http://www.
netflix.com/Default?mqso=60190075> click here
<http://us.adserver.yahoo.com/l?M=298184.6018725.7038619.3001176/D=groups/S=
:HM/A=2593423/rand=513809759>
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
Hi,
We just noticed that certain parts that were added to a job (these parts
are _not_ part-numbered, or in our BOM) showed up in p.o. suggestions,
What flag or setting do I need to set in order to have suggestions pick
Duane
NOTICE: This communication may contain privileged or other confidential information for the sole use of the designated recipients. If you have received it in error, please advise the sender by reply email and immediately delete the message and any attachments without reviewing, copying or disclosing the contents.
If you are on 6.1, go to the master part, click on the Inv/Purch button. In
there are two flags, one to process MRP and one to create PO Suggestions.
M. Manasa Reddy
ERP Specialist
Email: mreddy@...
Hi,
Duane
ADVERTISEMENT
Yahoo! Groups Links
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Hi,
in the master BOM, so I can't set these flags. These flags _are_ set on
the top-level part (the output for the job, which has been put into the
parts master)
Duane
> M. Manasa Reddy
> ERP Specialist
> Email: mreddy@...
> Hi,
> (these parts
> suggestions,
> suggestions pick
> Thanks,
> Duane
> the contents.
> ADVERTISEMENT
> Yahoo! Groups Links
> Terms of Service.
> to enable access. )
> Yahoo! Groups Links
When you add the items to the job as a material, is the 'Purchase Direct'
flag checked off?
Hi,
parts master)
Duane
> M. Manasa Reddy
> ERP Specialist
> Email: mreddy@...
> Hi,
> (these parts
> suggestions,
> suggestions pick
> Thanks,
> Duane
> the contents.
> ADVERTISEMENT
> Yahoo! Groups Links
> Terms of Service.
> to enable access. )
> Yahoo! Groups Links
Yahoo! Groups Links
Hi,
> 'Purchase Direct'
> flag checked off?
Yes, it was.
Duane
> Hi,
> _are_ set on
> put into the
> parts master)
> Thanks,
> Duane
> > M. Manasa Reddy
> > ERP Specialist
> > Email: mreddy@...
> > Hi,
> > (these parts
> > suggestions,
> > suggestions pick
> > Thanks,
> > Duane
> > the contents.
> > ADVERTISEMENT
> > Yahoo! Groups Links
> > Terms of Service.
> > to enable access. )
> > Yahoo! Groups Links
> You must have
> Builder and
> Yahoo! Groups Links
> to enable access. )
> Yahoo! Groups Links
