When a user print previews a crystal report (generally a modifed report)
they receive a 599 error. Problem is occurring on NT, Win98/95 systems
Resolution: Crystal is calling upon P2bxbse.dll, as well as using OCX
controls
User needs to run the vcopy.dll utility and unregocx on the problem
workstations
HOW TO RUN:
1. Go to a DOS prompt and change into the C:\Windows\System directory prompt
to read C:\Windows\System>
2. This step will unregister all OCX files for the Vantage main menu on that
workstation. Do not use a colon or slash. You will need to perform this step
for both drives, as follows:
a) At the C:\Windows\System> prompt, enter in the batch file name and path
followed by a space and then the mapped drive letter where Vantage is
located. (i.e: C:\Windows\System> V:\Vantage\UNREGOCX V and then press the
Enter key.
V=mapped drive
b) At the C:\Windows\System> prompt, enter in the batch file name and path
followed by a space and then the C:\ drive. (i.e. C:\Windows\System> prompt
type: V:\Vantage\UNREGOCX C
V= mapped drive
3. Before logging back into Vantage run the VCOPYDLL.EXE.
The file VCOPYDLL.EXE which can be run at any workstation to either fix a
problem workstation or to assist in setting up a new workstation.
The VCOPYDLL.EXE is located in your V:\Vantage folder. The following are
steps for setting up new NT and Win95 workstations.
a) Using Explorer, locate the VCOPYDLL.EXE in the V:\Vantage folder and
double click it.
b) Once the Vcopydll.exe is complete, Reboot the workstation by powering off
and restarting.
c) Log back into Vantage, all Vantage OCX's will be re-registered
d) Log into Vantage and try report, it should now print preview without the
599 error
e) if the 599 error is not corrected replace the prosql32.dll from a working
workstation or contact Vantage Tech support to have it sent.
f) if the error stems from a modified report with sub-reports using ODBC
this could be from this driver (PGPRO915.DLL) . Using the "old" Merant 3.6
drivers (IVPRO15.DLL) works fine.
This is based on the ODBC Error:
1157 "Specified driver could not be loaded due to system error 1157
Sent: woensdag 28 november 2001 14:57
Subject: RE: [Vantage] ODBC Error 1157
We are using Merant 3.60 32-bit Progress SQL92 v9.1a. Yes there are sub
reports in the traveler.
Sonya Cover
Electron Energy Corp.
Sent: Wednesday, November 28, 2001 8:15 AM
Could you give some additional information?
Which drivers are you using?
Merant 3.60 32-bit progress (ivpro15.dll) or the
Merant 3.60 32-bit progress SQL92 v9.1a (pgpro915.dll)
and are you using sub reports in the traveler?
Erik Weiffenbach
Sent: dinsdag 27 november 2001 20:46
Subject: [Vantage] ODBC Error 1157
We just upgraded to 5.00.334. When we went to print our
traveler/router there were some problems with it and we found out
that is because the table we are using has been changed. So in the
process of trying to correct this problem, I got ODBC Error
(MERANT 3.50 32-bit PROGRESS).
Any suggestions as to what the problem is?
Sonya Cover
eec@...
controls
workstations
HOW TO RUN:
Enter key.
V=mapped drive
V= mapped drive
double click it.
and restarting.
599 error
Sonya Cover
Erik Weiffenbach
Sonya Cover
eec@...
