ODBC Error- Invalid attribute in connection string
Hi there, Did anyone help you with the problem you had? I am installing
Merant driver in a week and would like to make sure that I wont come across
to any problems. I would like to know how you fixed it.
Marites
Sent: Friday, October 20, 2000 9:04 AM
To: vantage@egroups.com
Subject: [Vantage] ODBC Error- Invalid attribute in connection string
Help! I installed the new Merant ODBC Progress drivers on my Desktop and
keep getting this error when I try to test connection:
[MERANT][ODBC PROGRESS driver] Invalid attribute in connection string:
DBQ.[MERANT][ODBC PROGRESS DRIVER][PROGRESS] Disconnected from server
because database name was incorrect. [437].[MERANT][ODBC PROGRESS driver]
[PROGRESS] Error establishing Open Interface Driver connection. [2575].
I installed it on my Notebook first and have no problem connecting. Has
anyone else have this problem?
eGroups Sponsor
(Note: If this link does not work for you the first time you try it, go
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
Ed,
I have gotten many errors installing ODBC. My problems were always because
I typed something wrong, left a dlc variable referenced or something. Go
through every step again carefully and re-check that you did everything
correctly, this always solved it for me. Also, make sure your v: drive (or
whichever letter you use) is mapped. I've forgotten that before to.
Wow, I sound very incompetent.
Sarah
Did you copy the prosql32.dll file from the \Progress\Bin directory to your
c:\windows\system folder (win 95/98) or c:\winnt\system32 folder (NT)? Or
you can download the "Vantage 4.00 Merant ODBC Install Guide" from Epicor
web page and look at the Appendix A Troubleshooting section for error
message 437 and 2575.
Sent: Friday, October 20, 2000 11:04 AM
connection string
Desktop and
connection string:
from server
PROGRESS driver]
connection. [2575].
connecting. Has
-------------------------- eGroups Sponsor
Report Files, please go to the following link:
you try it, go to www.egroups.com, login and be sure to save your password,
choose My Groups, choose Vantage, then choose Files. If you save the
password, the link above will work the next time you try it.)
