Off Topic - Win 2000 NT Pro. - HP Printer Woes
Which W2K Service Pak are you running? I had issues with the HP1100 and an
HP2100 until I installed SP2. Also, make sure you are using the PCL driver
(I can't remember if it is PCL 5 or 6 for the 1100).
Lydia
Sent: Thursday, October 17, 2002 4:43 AM
Subject: [Vantage] Off Topic - Win 2000 NT Pro. - HP Printer Woes
I recently upgraded computers and am running Windows 2000
Professional NT. I am using the same HP Laserjet 1100 printer that I
have been using for years (previously on Win 95). I purchased updated
software from HP and was able to install the printer and get it
working fine. The problem comes when I log off windows. Once I return
to a login prompt and log back in to windows the printer stops
working. The printer still shows up, but when I try to print NOTHING
happens. The only way I have been able to get the printer working is
to delete the printer and reinstall. This happens EVERY time I log
off.
Thanks in advance,
off.
Thanks in advance,
I sometimes had the same problem with my 1100 and have traced it down to
the USB port. When it happens I unplug the USB cable and the power
cable from the printer, then power off the computer and reboot. The
last time this happened I deleted the USB hub from the Device Manager
and let Windows re-install the drivers and that seems to have fixed the
problem as it hasn't happened for about 3 months now.
Hope this helps.
>off.
>Thanks in advance,
>Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
>(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
>(2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
>(3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
John Himebaugh, MIS
InterOcean Systems, Inc.
3540 Aero Court
San Diego, CA 92123
Voice: 858.565.8400
Fax: 858.268.9695
