Off Topic - Windows shell
Not sure if it could be done in MS Access using VBA, but I have written
Visual basic programs where I set them to run full screen, remove the
min/max functions and tie the windows shutdown/reboot API call to the close
procedure of the program. Then edit the registry and launch this
application in the window\currentverion\run setting (just putting it in the
startup folder will not work because users can override and not have any of
the startup folder programs run by holding down the shift key while logging
in.). That's not saying they still can't boot to safe mode or even DOS and
edit stuff, but this is a little more tougher for the common users to get
around.
Sent: Friday, August 22, 2003 9:37 AM
To: Vantage Groups (E-mail)
Subject: [Vantage] Off Topic - Windows shell
Does anybody know how I could accomplish this through Group Policies or
Third Party Software:
I need a workstation that is completely secure and only shows a Microsoft
Access program when a user logs in. I don't want the user to be able to get
to the desktop, run any other programs or be able to exit the Access
program. All I want is a Microsoft access program menu to show. This menu
will be linked to certain documents in Word, Excel and PDFs but the desktop
should always be Access. Any ideas how I might accomplish this?
Jasper
Does anybody know how I could accomplish this through Group Policies or Third Party Software:
I need a workstation that is completely secure and only shows a Microsoft Access program when a user logs in. I don't want the user to be able to get to the desktop, run any other programs or be able to exit the Access program. All I want is a Microsoft access program menu to show. This menu will be linked to certain documents in Word, Excel and PDFs but the desktop should always be Access. Any ideas how I might accomplish this?
Jasper
Look at Fortress 101 software by Fortress Grand Corportation.
Patrick Winter
Jasper
------------------------ Yahoo! Groups Sponsor ---------------------~--> Buy
Ink Cartridges or Refill Kits for Your HP, Epson, Canon or Lexmark Printer
at Myinks.com. Free s/h on orders $50 or more to the US & Canada.
http://www.c1tracking.com/l.asp?cid=5511
http://us.click.yahoo.com/l.m7sD/LIdGAA/qnsNAA/PhFolB/TM
You can do this with group policies. Go to the following link and read
up and download the Intellimirror Scenarios. You will want what they
call a TaskStation. This only runs one application and doesn't have a
desktop or start menu.
http://www.microsoft.com/technet/treeview/default.asp?url=/technet/prodt
echnol/windows2000serv/deploy/confeat/grppolsc.asp
Hope this helps,
Ted Kitch
ted@...
accomplish this?
Jasper
ADVERTISEMENT
<http://rd.yahoo.com/M=261419.3724993.5015550.1269402/D=egroupweb/S=1705
007183:HM/A=1724960/R=0/SIG=136fcaifi/*http:/ads.x10.com/?type=href&line
id=3724993&property=egroupweb&aposition=HM&random=1061563012671625>
<http://us.adserver.yahoo.com/l?M=261419.3724993.5015550.1269402/D=egrou
pmail/S=:HM/A=1724960/rand=356742373>
Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
We use Fortres in our shop. I block off everything but Vantage in our
case. We have windows 95-2000 PC's out there. It works well to disable
Start Up options before you even hit Windows (like F8). I also disable
the floppy drive and make sure that it is not set to be the first boot
device in Setup. Password Setup. I downloaded TweakUI and set the auto
log on options so they don't even have to logon. You know, some days I
really miss the AS400.
accomplish this?
Jasper
