Hard drive configuration for Vantage Server
Speed is not the issue with RAID 5 vs. RAID 10.
Having experienced a 2 disk failure at the same time (raid 10 gives you
a good shot at surviving that type of failure), that is one very good
reason I will never allow RAID 5 for Vantage again. Besides the fact
that RAID 5 is not a supported configuration for a progress database.
Just my $.02
Aaron Hoyt
Vantage Plastics
Joe Luster wrote:
> We run Vantage in a VM just fine. However, we are SQL and the SQL
> server is not in a VM.
> The more disks you have in your RAID configuration, the faster the
> speed. We run our SQL DBs on a SAN which is RAID 6 across 14 drives.
> That blew away our RAID 10 configuration with only 4 drives.
> Sometimes, a RAID 10 configuration can be slower than a RAID 5
> configuration depending on the amount of drives used. Very rarely though.
> Joe Luster
> Network Administrator
> Cold Jet, LLC
> 455 Wards Corner Road
> Loveland, Ohio 45140
> 513-716-6308
> 513-831-1209 (fax)
> www.coldjet.com<http://www.coldjet.com <http://www.coldjet.com>>
> [cid:image001.jpg@01C9021C.589724D0
> <mailto:image001.jpg%4001C9021C.589724D0>]
> Setting industry standards in dry ice technology and solutions for
> over 20 years.
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>] On
> Behalf Of Charles Carden
> Sent: Friday, August 15, 2008 9:55 AM
> Subject: RE: [Vantage] Hard drive configuration for Vantage Server
> Charlie,
> Your instructor is absolutely correct in the need to have your server
> configured with Raid 1 and Raid 10. The amount of gain that you will
> see will be dependent upon the amount of memory you have in your
> server. Also, never run Vantage on a VM.
> If you can install a 64 bit operating system with at least 8 to 10 GB
> of memory (dependent upon the number of users) you will also see a
> great improvement in background processes. We saw as much as a 400%
> improvement in some processes by going 64 bit. You need to assign as
> much memory as possible to your database (dependent upon DB size).
> <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>]
> On Behalf Of Charlie Wilson
> Sent: Friday, August 15, 2008 6:54 AM
> Subject: [Vantage] Hard drive configuration for Vantage Server
> All,
> I recently went to the admin class for training and pretty much
> learned that
> the way our server's hard drives are configured is no good. According
> to the
> instructor he recommended that the OS / APP should sit on a Raid 1
> drive and
> the DB should sit on a raid 10 (1+0) drive. Currently everything sits on a
> single raid 5 drive that is also shared by several other servers (VM). I
> was wondering if any of you all had experimented with different RAID
> configurations and seen a large gain in having the raid configurations set
> as stated by the instructor. I would like to recommend to my company
> that we
> reconfigure this server to the configurations as recommended by the
> instructor but before I do so I wanted to see if it was going to be worth
> the money and time we will have to invest to make these changes.
> I plan to set aside a raid 1 and raid 10 that will be for our server and
> that will not be shared by any other servers. In order to do this I
> will end
> up having to buy more SAS drives and basically pull everything off the
> server and rebuild it.
> ~Charlie
> DISCLAIMER:
> This e-mail, including attachments, may include confidential and/or
> proprietary information, and may be used only by the person or entity
> to which it is addressed. If the reader of this e-mail is not the
> intended recipient or his or her authorized agent, the reader is
> hereby notified that any dissemination, distribution or copying of
> this e-mail is prohibited. If you have received this e-mail in error,
> please notify the sender by replying to this message and delete this
> e-mail immediately.
All,
I recently went to the admin class for training and pretty much learned that
the way our server's hard drives are configured is no good. According to the
instructor he recommended that the OS / APP should sit on a Raid 1 drive and
as stated by the instructor. I would like to recommend to my company that we
that will not be shared by any other servers. In order to do this I will end
~Charlie
Hello Charlie
Back in a previous life I had Vantage 5.0 on a raid 5 with 20 users.
When we switch to raid 10 we saw at least a 3 fold gain in speed for
Vantage.
Mark D
Of Charlie Wilson
Sent: Friday, August 15, 2008 7:54 AM
All,
that
the
and
a
set
that we
worth
end
~Charlie
Charlie, I know it seems a pain, but you will see great improvements in the RAID 10 setup.
----- Original Message ----
Sent: Friday, August 15, 2008 6:53:52 AM
All,
~Charlie
Charlie,
Your instructor is absolutely correct in the need to have your server configured with Raid 1 and Raid 10. The amount of gain that you will see will be dependent upon the amount of memory you have in your server. Also, never run Vantage on a VM.
If you can install a 64 bit operating system with at least 8 to 10 GB of memory (dependent upon the number of users) you will also see a great improvement in background processes. We saw as much as a 400% improvement in some processes by going 64 bit. You need to assign as much memory as possible to your database (dependent upon DB size).
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Charlie Wilson
All,
~Charlie
DISCLAIMER:
This e-mail, including attachments, may include confidential and/or proprietary information, and may be used only by the person or entity to which it is addressed. If the reader of this e-mail is not the intended recipient or his or her authorized agent, the reader is hereby notified that any dissemination, distribution or copying of this e-mail is prohibited. If you have received this e-mail in error, please notify the sender by replying to this message and delete this e-mail immediately.
We run SAS drives has anyone noticed a difference between the 15K rpm drives
and the 10K?
_____
Tony Hughes
Sent: Friday, August 15, 2008 8:38 AM
Subject: Re: [Vantage] Hard drive configuration for Vantage Server
RAID 10 setup.
From: Charlie Wilson <foamdesigncsw@ <mailto:foamdesigncsw%40yahoo.com>
yahoo.com>
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
All,
~Charlie
No virus found in this incoming message.
Checked by AVG - http://www.avg.com
Version: 8.0.138 / Virus Database: 270.6.3/1611 - Release Date: 8/14/2008
6:20 AM
There is about a 30% performance improvement in the 15K drives for disk intensive applications. Data retrieval is considerably better. The cost difference has shrunk over the last few years which makes the 15K drives more affordable.
Sent: Friday, August 15, 2008 9:29 AM
and the 10K?
_____
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Tony Hughes
RAID 10 setup.
yahoo.com>
All,
~Charlie
6:20 AM
DISCLAIMER:
We run Vantage in a VM just fine. However, we are SQL and the SQL server is not in a VM.
The more disks you have in your RAID configuration, the faster the speed. We run our SQL DBs on a SAN which is RAID 6 across 14 drives. That blew away our RAID 10 configuration with only 4 drives. Sometimes, a RAID 10 configuration can be slower than a RAID 5 configuration depending on the amount of drives used. Very rarely though.
Joe Luster
Cold Jet, LLC
513-716-6308
513-831-1209 (fax)
www.coldjet.com<http://www.coldjet.com>
[cid:image001.jpg@01C9021C.589724D0]
Setting industry standards in dry ice technology and solutions for over 20 years.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Charles Carden
Charlie,
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Charlie Wilson
All,
~Charlie
DISCLAIMER:
