On-prem system menu links did not upgrade properly
I’ve found that some of our system menu links did not upgrade when we moved to 2025.2. We started with E9, went to E10, E11, E12 now. For example the (system) Configuration Upgrade Dashboard doesn’t work:
In my clean install 2025.2 sandbox environment, it does work. Here is how the menu item looks (these are all default from install):
But in our live environment, the menu item looks like this:
I ran some db queries and it is a hodgepodge of mismatches between clean install and legacy upgraded. I have a ticket open with Epicor but so far nothing. AI wants me to fix database directly. :dumpster_fire:
Anyone run across this / have a fix / know exactly what to ask for? Thank you!
Did you already flip Enable New UI? Its in kinetic menu maintenance in the overflow menu.
Yes I sure did!
What does your Configuration Upgrade Dashboard menu maintenance look like? Mine is wrong…
It’s wrong, this is what it should look like, support probably has a data fix for it:
