Open Edge 10.1C on Server 2003 64 Bit
It likely was a corrupted installation of JVM. We started over with Epicors support helping us and got everything running smoothly. We weren't able to repair only the JVM, but since we weren't to far into the setup it wasn't a big deal to start clean and install to a new directory.
Thanks for the suggestion.
--- In vantage@yahoogroups.com, "Ned" <TechnoBabbly@...> wrote:
> There we go, a problem with the JVM.
> I wold re-install the Java Runtime Environment after removing any and all
> that are already on the server.
> From: "tomrippity02" <bateman_aaron@...>
> To: <vantage@yahoogroups.com>
> Sent: Tuesday, May 19, 2009 11:23 AM
> Subject: [Vantage] Re: Open Edge 10.1C on Server 2003 64 Bit
> > Just two errors when you restart the system, and they are pretty vague.
> > JVMstart.exe encountered a problem and needed to close.
> > Progress client encountered a problem and needed to be closed.
> > --- In vantage@yahoogroups.com, "Ned" <TechnoBabbly@> wrote:
> >> Any error messages?
> >> From: "tomrippity02" <bateman_aaron@>
> >> Sent: Tuesday, May 19, 2009 11:05 AM
> >> > Did anyone find a solution for this problem? We are a new
> >> > implementation
> >> > and are having the same issue. Server 2003 64 bit license and also E9.
> >> > Aaron
> >> > --- In vantage@yahoogroups.com, "bw2868bond" <bwalker@> wrote:
> >> >> Setting up a test server for E9.
> >> >> I have it all installed but can't get Progress Explorer Tool to run
> >> >> This is not Server 2008
> >> >> Admin service for 10.1C is started
> >> >> Anyone else experience this?
> >> >> bw
> >> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> >> > have already linked your email address to a yahoo id to enable
> >> > access. )
> >> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> >> > and
> >> > Crystal Reports and other 'goodies', please goto:
> >> > http://groups.yahoo.com/group/vantage/files/.
> >> > (2) To search through old msg's goto:
> >> > http://groups.yahoo.com/group/vantage/messages
> >> > (3) To view links to Vendors that provide Vantage services goto:
> >> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
bw
Did anyone find a solution for this problem? We are a new implementation and are having the same issue. Server 2003 64 bit license and also E9.
Aaron
> bw
Any error messages?
> Aaron
>> bw
> Any error messages?
> > Aaron
> >> bw
>> Any error messages?
>> > implementation
>> > Aaron
>> >> bw
>> > access. )
>> > and
Double check your authorized user by right clicking on Localhost in PET.
I have my E9 test server running 2003 Enterprise 64 bit with no
problems. PET works with no problems.
Cliff Drumeller
IT Manager
Mass Precision, Inc.
408 786 0348
408 314 7420 cell
Of Ned
Sent: Tuesday, May 19, 2009 8:18 AM
Subject: Re: [Vantage] Re: Open Edge 10.1C on Server 2003 64 Bit
Any error messages?
<mailto:bateman_aaron%40hotmail.com> >
To: <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
implementation
> Aaron
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
>> bw
and
<http://groups.yahoo.com/group/vantage/linksYahoo> ! Groups Links
We are unable to use the PET so that would not be an option. We are running 2003 Standard Standard Service Pack 2, so perhaps its possible there is some difference between Standard and Enterprise that helped you avoid the issue we are having.
Aaron
> Cliff Drumeller
> IT Manager
> 408 786 0348
> 408 314 7420 cell
> Of Ned
> Any error messages?
> implementation
> > Aaron
> >> bw
> and
That was so long ago :o)
I think I uninstalled the whole deal and created an Epicor904 folder at root of drive and installed there - I could not tolerate drilling into program files (x86) .... to find anything. For my sanity I Kept It Simple.....
Good Luck
bw
> Aaron
> > bw
If both 10.1B and 10.1C are on the same server, you have to change the ports on one of them. See 10068MPS. We chose to change the ports on 10.1B. But you have to right-click on local host in PET, go to properties, Advanced tab, and ensure it's on 20555. Sometimes it changes back to the 20931.
Sent: Tuesday, May 19, 2009 8:53 AM
Good Luck
bw
> Aaron
> > bw
