Open Orders Report
Hello im wondering if there is anyway I can create a BAQ off simply the order number with the lines and the part number per line and the customer ID i would then do a subquery for eta of stock
From there I would then want to automate this to be sent to customers but based on the customerID in the first column so the correct customer gets the correct information
There is a system BAQ called zSalesOrderBackLog. You can use this as a starting point.
Is there a way to break the report by CUSTOMER ID so like if i created a routing for it
The built in report “Sales Order BackLog Report” does have CustID in it, so it should be possible to create a routing. We do not have APR so cannot say for sure.
