OT-Recover file from server deleted - THANKS
Thank you, Scott and Gary. I will start shadow copy in certain folders
of my server. I cannot believe that in your computer you have the option
to use the recycle bin but not when you delete from a mapped
drive....Thanks again.
Mario E. Aguirre - IT Manager
Lakin General Corporation, Inc.
Of Scott Litzau
Sent: Wednesday, May 09, 2007 1:20 PM
Subject: RE: [Vantage] OT-Recover file from server deleted
Shadows copies only works if 1. It is installed and running and 2. If
the
file existed when Shadow Copy ran.
For instance, I have my Shadow Copies run at 7:00 am and at 1:00 pm. If
the
file existed at those times then you can use previous versions to
recover
the file. To recover a deleted file at that time you would create a
dummy
file called exactly what the file was called. And it has to be exact.
Then
you right click, click on properties, click on previous Versions and
then
restore the file.
Since this delete was in a few minutes then you most likely do not have
a
previous version (shadow copy) of the file.
There are Undelete Utilities that can recover the file. Do a Google
search
for undelete utility and it will give you a bunch of results.
Scott Litzau
Behalf Of
Garyphold
Sent: Wednesday, May 09, 2007 11:04 AM
Mario,
Are you using Shadow Copy on your server? If so, you can right click on
the folder the file is in (providing it is a network-shared folder) and
select properties. There should be a previous versions tab. The rest
is self-explanatory. I think the shadow copy was a separate download
from the Microsoft site. A consultant I work with installed it.
Gary
Behalf
Of Mario Aguirre
Sent: Wednesday, May 09, 2007 11:21 AM
Subject: [Vantage] OT-Recover file from server deleted
One of my users deleted a pdf he put in our server a few minutes ago (no
back up) and now wants to recover it. Any idea how?
Thank you.
have
and
Yahoo! Groups Links
Thank you.
Mario,
Gary
Of Mario Aguirre
Thank you.
Shadows copies only works if 1. It is installed and running and 2. If the
For instance, I have my Shadow Copies run at 7:00 am and at 1:00 pm. If the
file existed at those times then you can use previous versions to recover
the file. To recover a deleted file at that time you would create a dummy
file called exactly what the file was called. And it has to be exact. Then
you right click, click on properties, click on previous Versions and then
restore the file.
Since this delete was in a few minutes then you most likely do not have a
There are Undelete Utilities that can recover the file. Do a Google search
Scott Litzau
Garyphold
Mario,
Gary
Of Mario Aguirre
Thank you.
Yahoo! Groups Links
