At 06:45 PM 10/14/2004, you wrote:
utility http://www.digallery.com/diskdata/ does a great job of showing
what's eating your space. Some quick cleanup may go a long way.
since Symantec bought it out.
Easy solution: Win 2000 and up allow you to mount a disk partition at an
arbitrary point in a filesystem (like Unix has always done) rather than
assigning a drive letter. If it's the users data eating space, you could
add a drive, and mount it at C:\Documents and Settings. That would spare
you the hassle of changing all the paths around.
-Wayne Cox
Twenty Three, Inc. -- Information Technology Consulting
828-685-2338
>My Terminal server is out of drive space on the C: drive. Two questions,Yeah, but I don't know how off the top of my head. This snazzy little
>can I move the profiles and home directories to another server?
>Can I use drive copy to copy the C: drive and then put the contents on aI've used Drive Image to do similar things, but I haven't messed with it
>bigger drive?
-Wayne Cox
828-685-2338
