Overload Informer only seems to use the hours from 1 of the 2 resources in a resource group. Shop Load Report uses hours for both resources in the same group.
Any Ideas why? Or what I might be missing.
Did you ever resolve your issue with Overload Informer only using 1 of the resources in the group? I’m running into this same issue - we are fine overall because there are 3 resources in the group, but Overload Informer appears to only look at resource #1 and indicates its well overloaded.
Jenn
The answer that I came up with was that we were not using the “Advance Planning and Scheduling module”.
