Part inspections
We control it by the part class.
Thomas F. Wright
Design Engineer
Hydraulic Development & Mfg. Co.
Phone: 716-694-8004 x223
Fredy Venczel
<fvenczel@xebecin To: "'vantage@yahoogroups.com'" <vantage@yahoogroups.com>
c.com> cc:
Subject: RE: [Vantage] PART INSPECTIONS
08/18/2003 01:07
PM
Please respond to
vantage
Thanks for the answer Scott but I'm just looking for a way to do it
automatically. These parts are stocked parts so its nothing the job planner
will do and I don't want to leave it up to the receiver. If we set up the
Vendor as inspection required then every part will go into the inspection
process whether it is required to or not.
Fredy Venczel
Sent: August 18, 2003 12:56
To: 'vantage@yahoogroups.com'
Oops, change that, because I just realized that I forgot another
way:
4. In receipt entry, a receiver always has the option of routing
material
to inspection, even if inspection is not required for the vendor or
if a
requestor, buyer or job planner did not indicate that inspection was
required.
Regards,
Scott
Sent: Monday, August 18, 2003 12:36 PM
As far as I know, there are only three other ways:
1. In vendor maintenance, you can check the "inspection
required"
checkbox to require that all items from that vendor are inspected;
2. If requisitions are used, a requestor can specify that
inspection is
required for requested items; and,
3. When planning to purchase material direct to a job, a job
planner
can check the "inspection required" checkbox to require that the
material is
inspected.
HTH.
Regards,
Scott
Sent: Monday, August 18, 2003 11:58 AM
Subject: [Vantage] PART INSPECTIONS
I'm just curious how you out there handle this. We have a supplier
where
some but not all parts need to be inspected. Do you leave it up to
the buyer
to click on inspection required when creating the purchase order or
do you
set up a different part class and default it to inspection required
or is
there any other way?
Fredy Venczel
Yahoo! Groups Sponsor
I'm just curious how you out there handle this. We have a supplier where
some but not all parts need to be inspected. Do you leave it up to the buyer
to click on inspection required when creating the purchase order or do you
set up a different part class and default it to inspection required or is
Fredy Venczel
1. In vendor maintenance, you can check the "inspection required"
2. If requisitions are used, a requestor can specify that inspection is
3. When planning to purchase material direct to a job, a job planner
can check the "inspection required" checkbox to require that the material is
inspected.
HTH.
Regards,
Scott
Fredy Venczel
Oops, change that, because I just realized that I forgot another way:
4. In receipt entry, a receiver always has the option of routing material
to inspection, even if inspection is not required for the vendor or if a
required.
Regards,
Scott
inspected.
HTH.
Regards,
Scott
Fredy Venczel
Fredy Venczel
way:
material
if a
required.
Regards,
Scott
required"
inspection is
planner
material is
inspected.
HTH.
Regards,
Scott
where
the buyer
do you
or is
Fredy Venczel
Fredy,
You can also flag for inspection in the part class. This would cause any
inventoried part with this class to automatically need to be inspected.
Erica Steffens
Sent: Monday, August 18, 2003 12:08 PM
Fredy Venczel
way:
material
if a
required.
Regards,
Scott
required"
inspection is
planner
material is
inspected.
HTH.
Regards,
Scott
where
the buyer
do you
or is
Fredy Venczel
<http://rd.yahoo.com/M=259395.3614674.4902533.1261774/D=egroupweb/S=1705007183:HM/A=1524963/R=0/SIG=12o885gmo/*http:/hits.411web.com/cgi-bin/autoredir?camp=556&lineid=3614674?=egroupweb&pos=HM>
<http://us.adserver.yahoo.com/l?M=259395.3614674.4902533.1261774/D=egroupmail/S=:HM/A=1524963/rand=663180716>
<http://docs.yahoo.com/info/terms/> Terms of Service.
This message (including any attachments) is confidential and may be privileged. If you have received it by mistake please notify the sender by return e-mail and delete this message from your system. Any unauthorized use or dissemination of this message in whole or in part is strictly prohibited. Synovis Life Technologies
