Plan As, Pull As or Phantom
Hi,
You can find some of these definitions within the Epicor help menu of your version.
Here is what is listed for Phantom BOM:  A phantom bill of material represents a part that is built, but not stocked before it is used in the next level of manufacturing. When Material Requirements Planning (MRP) processing is run, the program logic will blow through phantom items straight to their components when determining material needs.
Personally, we used them for a a few things but went back to a straight BOM structure.
The Pull As
Assembly means you want to pull the item into a job as a make-to-order item (if unchecked).  If checked, it means you want to pull the item into a job as pull/pick from stock.
We don't use Plan as Assembly, so not familiar, but the Epicor definition is:  Plan As Assembly ->
Select this check box to indicate this material requirement is fulfilled from stock. If not enough stock is available during the manufacturing lead time, it will be planned as a subassembly by the MRP process.
Hello Community,
I am fairly new to Epicor and I have a project where I need to create a new BOM report that lists if the sub-assembly is Plan As, Pull As or Phantom. I was wondering if anyone could explain to me what the differences are.
Thanks!
