Thanks to everyone for your respones.
Jay from Tech support used web-ex to take control of one of our
troubled machines. He searched the registry for 9.1a and removed all
entries. Didn't seem to help and he fumbled around a while,
rebooted, tried some things, until then he removed the -q parameter
out of the vantage.mfg file. He said that that parameter tells the
computer to start up quickly by looking for settings already in
memory. And by taking it out, it will have to look for whatever the
current settings are. Well it worked after that. Were not exactly
sure what did it, but I'll try it on another machine next week and
let you know what happens.
Have a great weekend and thanks again.
Brian
Brian
--- In vantage@yahoogroups.com, "Mark Dupuis" <dupuism@r...> wrote:
> There is an unregocx program from epicor that gets rid of these.
> Mark Dupuis
> -----Original Message-----
> From: Brian Stenglein [mailto:bstenglein@c...]
> Sent: Friday, January 09, 2004 3:13 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Post Upgrade Server Conflicts
> Patrick,
> The search does reveal a lot of OCX entries, but I'm getting an
error
> when I try to remove them. Cannot delete HELPDIR: error while
> deleting key.
> Brian
> --- In vantage@yahoogroups.com, pjw@s... wrote:
> > Search your clients registry for \\Oldservername this should
show
> old
> > vantage entries. Should be a bunch of vantage 5.0 ocx stuff
along
> with the
> > old drive mapping. Deleting them should get you going. When
> switching from
> > an old server it's a good idea to take baby steps like, switch
to
> new box
> > and run live for a week then unmap old server shared drive and
wait
> a week.
> > (You usually get a message that "there are x number connections
do
> you want
> > to continue?". These are old ocx file references in the
registry.
> The next
> > baby step might be a week later to shutdown the server and see
if
> anyone
> > yells. Also it's easy to forget that this old server may be
linked
> in time
> > sync's across the network, a print server, a antivirus server,
or
> even worse
> > a backup domain controller.
> > Patrick Winter
> > Sent: Friday, January 09, 2004 12:47 PM
> > Subject: [Vantage] Post Upgrade Server Conflicts
> > Help.
> > Upgraded from 5.0 to 6.0 over Thanksgiving. We added a new
server
> in
> > the process so Vantage 5 was running on one server W drive, and
> > Vantage 6 was running on a new server V drive.
> > We installed the clients for 6.0 ahead of implementation
weekend so
> > users could get a feel for the changes. This means both 5 and 6
> were
> > on the machines at the same time. Progress 9.1A and 9.1D were
also
> > present simultaneously. Everything has gone fine until... We
are
> in
> > the process of planning another use for the old Vantage server.
> > However, disconnecting the w: drive from clients will prevent
them
> > from being able to get into Vantage 6, eventhough that server
has
> > nothing to do with 6.
> > With help from support I was able to get Vantage 6 working
without
> > the w:\ drive by uninstalling both versions of progress,
deleting 6
> > registry keys for environment variables (DLC, IDLC, IPROMSGS,
PATH,
> > PROCFG, and PROMSGS). Then reinstalling the Vantage Client for
6.
> > However, after doing that, Progress Report Builder reports no
> longer
> > function from within Vantage. I'm getting error, "Unable to
open
> > convmap file '\convmap.cp'.
> > With urging from support I tried to hack out everything in my
> > registry to do with either version of Vantage, which there are
> dozens
> > if not hundreds of entries and reinstall Vantage. Vantage
wouldn't
> > run at all. So now I'm formatting that machine to get it
working
> > again. We have over 50 clients that will be affected by this
and
> > we'd rather not set them all up from scratch if we can find a
> > solution, but I don't like the option of deleting everything
from
> the
> > registry either.
> > Anyone have some ideas? Also, what is the cause of this? Was
it
> the
> > fact that we had multiple versions running? Prior to the
upgrade
> > support said it would be fine? Does everyone else face problems
> like
> > this when upgrading?
> > Thanks,
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
You
> must have
> > already linked your email address to a yahoo id to enable
access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
> Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/links
> > Yahoo! Groups Links
> > To visit your group on the web, go to:
> > To unsubscribe from this group, send an email to:
> > vantage-unsubscribe@yahoogroups.com
> > Your use of Yahoo! Groups is subject to:
> http://docs.yahoo.com/info/terms/
must
> have already linked your email address to a yahoo id to enable
access. )
Builder and
> Yahoo! Groups Links
> a.. To visit your group on the web, go to:
> b.. To unsubscribe from this group, send an email to:
> c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
