Printing PickList from one plant, to another plant
Hello all,
I have made a Dashboard used by CS rep to see all open orders currently in the system. They have a view of both of our plants. I have added the Context menu on OrderNum to print the pickList for orders to be shipped today or the next day. This menu calls a customization of the PickListPrint Form, where I set all the necessary fields and launch a pdf preview, then close the form, so the user oinly sees the generated pdf…see this link Add SO Pick List to OrderHed.OrderNum context menu? - #2 by Hogardy
The issue I have is if I am in Plant A, the report will work for orders from plant A only.
If I need to print for plant B, The user needs to change its current plant, and launch the Dashboard again. Not really efficient…but they have been using it for the past 3 years.
Now we just bought a company which will add 6 new plants to deal with…
My question is:
How can I change the way I call the SOPick List report module in order to make it think it is launched from a specific plant so it’s logic will continue as designed ?
For instance, if the order is from plant B, only print SOPicklist from plant B… etc…
Would it need a new login in code ? using the specific plant, launch the module and then kill the connection when I close the form?
Thank you all for any input on this…
Pierre
Hi Pierre,
Can you pass the PlantID into the form as well? If you can then use something like:
using (CallContext.Current.TemporarySessionCreator.SetPlantID("PassedInPlant").Create())
   Do Something ;
Hope this helps
Mark
Thanks I will try that…instead of my original idea of opening a new session temporarely…
Will let you know!
Pierre
