I had the exact same problem.
I did this
1)Use the add and remove programs and remove Progress 9.1
2)Delete the folders within the Epic50 folder, you may have to pick the last
few file as some are unable to be deleted as there is a share violation.
There will be about 4 or 5 dll files left and the Vantage.exe you can't
delete
3)Make sure you have Internet explorer 5 on the machine
4)Double make sure that procontrol for vantage 4 is stoped
5)Triple make sure the Admin service for 9.0B is stoped in your services
section, I think that's what I did wrong.
Then Start again doing the install......Good Luck
I did this
delete
> -----Original Message-----
> From: Marites Marlar [SMTP:mmarlar@...]
> Sent: Monday, January 22, 2001 2:12 AM
> To: vantage@egroups.com
> Subject: [Vantage] problem upgrading to 5.0
> Is anyone having problems upgrading vantage 5.0? I tried to run schema
> changes for 10 hours and it froze up on me so I rebooted the machine and
> now
> I get the Dr. Watson Error _mprosrv.exe when I attempt to open progress
> explorer tool. I tried to uninstall progress but it keep telling me that
> it's in use even though it's not in the task manager. I am still waiting
> for
> the helpdesk support to help me but I thought I'd tried this egroups
> first.
> Marites Marlar
> MCP, MCSE, MCSE + I, A+, CNA
> MIS Department
> SPS Non-Ferrous
> (702) 262-9922 ext. 118
> To unsubscribe from this group, send an email to:
> vantage-unsubscribe@egroups.com
