Progress 32 bit Epicor Admin tools on 64bit server
I believe OE102a is still available to download from epicor’s FTP site.
Sincerely,
Patrick Winter
Sent: Monday, April 18, 2016 13:38
Subject: [Vantage] RE: Progress 32 bit Epicor Admin tools on 64bit server
Patrick, I “think” I know what happened.  We were hit hard with a “ransomeware” virus about a  month ago that took siege on our network and “encrypted” thousands of files (mostly .doc, .xls).  Since Epicor9 continued to run after we got hit, I didn’t think much about it.  I just now noticed that there were a ton of Javascript .js files in the OE102a directory that were corrupted and I’m guessing that’s what has screwed mine up.  I really don’t want to mess with the server trying to reinstall OpenEdge or anything but I’m betting if I had a copy of a good oe102a directory, I’ll bet I could copy over the corrupted files with the correct ones and fix my problem…..Any chance you might be able to “zip up” your oe102a directory and let me download it???
Best regards
Mike Abell
IT Manager
Flexial Corporation
a company of BOA Group
1483 Gould Drive, Cookeville, TN 38506, USA
Phone:    +1 931 432 8408
Fax:        +1 931 432 1889
Mail:        mabell@...
Website:  http://www.flexial.com
               http://
www.boagroup.com
Sent: Monday, April 18, 2016 1:20 PM
I’m running the same configuration as you,
We have our Epicor 9.05.702 with Progress Database installed on Windows 2008 Server 64 bit.
Also installation done by Epicor.
I’m behind on my patches, was thinking this may have caused the issue for you.
Sincerely,
Patrick Winter
Sent: Monday, April 18, 2016 13:11
Yes, exactly!
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Sent: Monday, April 18, 2016 12:42 PM
Just to confirm you want to run the Admin Tools, “Run Conversion Program”, “Run Progress Program”, “Run Progress Editor” and “UD Schema Update”?
Sincerely,
Patrick Winter
Sent: Monday, April 18, 2016 11:43
Subject: [Vantage] Progress 32 bit Epicor Admin tools on 64bit server
We have our Epicor 9.05.702 with Progress Database installed on Windows 2008 Server 64 bit.  Recently, our admin tools program has started to crash and will not run (it says Prowin32.exe has crashed, fault module name winnt.dll) .  I phoned into Epicor support for help and they told me that in order to run the Epicor Admin tools, I’d have to run it in a 32 bit environment.  Our admin tools had been working fine til now and I find it very hard to believe that we are the only company in the world that has the Epicor Admin tools installed on a 64 bit Win 2008 server.  I was NOT happy with Epicor’s response (especially since I had THEM install the system from scratch).   Can anyone verify that they are running the Epicor Admin tools (progress db) on their Windows 2008 64 Bit server?   Thanks in advance.
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
This e-mail and any attachments may contain confidential and privileged information. If you are not the intended and/or named recipient or recipients, please notify the sender immediately by return e-mail, delete this e-mail and destroy any copies. Any dissemination or use of this information by a person other than the intended recipient or recipients is unauthorized and may be illegal. Any views or opinions expressed in this email are those of the author and do not necessarily represent those of the Specialty Screw Corporation. Warning: Although precautions have been taken to make sure no viruses are present in this email, Specialty Screw Corporation cannot accept responsibility for any loss or damage that may arise from the use of this email or attachments.
This e-mail and any attachments may contain confidential and privileged information. If you are not the intended and/or named recipient or recipients, please notify the sender immediately by return e-mail, delete this e-mail and destroy any copies. Any dissemination or use of this information by a person other than the intended recipient or recipients is unauthorized and may be illegal. Any views or opinions expressed in this email are those of the author and do not necessarily represent those of the Specialty Screw Corporation. Warning: Although precautions have been taken to make sure no viruses are present in this email, Specialty Screw Corporation cannot accept responsibility for any loss or damage that may arise from the use of this email or attachments.   ­­
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Yes you can run it on 64 bits without having a 32Â
Here's how sorry the paste on my phone sucks
Summary:
How to setup the Admin Tools to run on Windows 64-bit server?
Details:
XA905
Issues:
  • The Epicor Admin Tools are not available on 64-bit
  • The Epicor Install Guide requires the installation of an Admin 32-bit Workstation
  • Running the Admin Tools on 64-bit returns a shared memory error such as "The shared memory is version 50331648; expected 12009 (1178)"
Resolution:
Although not mentioned in the install guide since 9.05.603 it is possible to setup the Epicor Admin Tools on a Windows 64-bit server
Steps:
  1. Make sure you are running at least Open Edge 10.2A with SP3 and HF 23
  2. Change the ProPath in the INI file specified in the Admin Tools shortcut to include the new 32 bit paths:
    e.g. E:\Epicor905\32\Server , E:\Epicor905\32\ClientServer
  3. Right Click the Epicor Admin Tools icon and change the START IN to also include the \32 folder:
    e.g. Full Start In: line would be: E:\Epicor905\32\ClientServer
  4. If it is on SQL, make sure you are not using a Read-Only schema holders and create a 32-bit DSN if necessary by running:
    C:\windows\SysWOW64\odbcad32.exe
  5. Edit the .PF files to use TCP packets vs a direct shared memory connection.
    Add the -N -H -S parameters. (-S will be the database port defined in oe102a\properties\conmgr.properties)
Example if you are running a Progress DB
BEFORE:
-Mm 1024 -mmax 65534 -Bt 4096 -s 8000 -yy 1970 -stsh 31 -inp 32000 -tok 4000 -TB 31….
-T "C:\EpicorData\"
-db "C:\Epicor905\db\mfgsys"
-cpinternal utf-8 -cpstream utf-8 -cprcodein utf-8 -cpcoll icu-uca
AFTER:
-Mm 1024 -mmax 65534 -Bt 4096 -s 8000 -yy 1970 -stsh 31 -inp 32000 -tok 4000 -TB 31 -TM 32 -D 500 -l 1000 -ttmarshal 5 -tmpbsize 8 -rereadnolock -lkwtmo 180
-T "C:\EpicorData\"
-db mfgsys -N TCP -H localhost -S 9400
On Monday, April 18, 2016, Mike Abell mabell@… [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p>
We have our Epicor 9.05.702 with Progress Database installed on Windows 2008 Server 64 bit. Recently, our admin tools program has started to crash and will not run (it says Prowin32.exe has crashed, fault module name winnt.dll) . I phoned into Epicor support for help and they told me that in order to run the Epicor Admin tools, I’d have to run it in a 32 bit environment. Our admin tools had been working fine til now and I find it very hard to believe that we are the only company in the world that has the Epicor Admin tools installed on a 64 bit Win 2008 server. I was NOT happy with Epicor’s response (especially since I had THEM install the system from scratch).  Can anyone verify that they are running the Epicor Admin tools (progress db) on their Windows 2008 64 Bit server?  Thanks in advance.Â
Â
Best regards
Mike Abell
IT Manager
Flexial Corporation
Phone:Â Â Â +1 931 432 8408
Fax:Â Â Â Â Â Â Â +1 931 432 1889
Mail:Â Â Â Â Â Â Â mabell@...
Website:Â http://www.flexial.com
              http://
www.boagroup.com
Â
</div>
<div style="color:#fff;min-height:0;"></div>
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
Sincerely,
Patrick Winter
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Yes, exactly!
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Sincerely,
Patrick Winter
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Sincerely,
Patrick Winter
Yes, exactly!
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Sincerely,
Patrick Winter
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Sincerely,
Patrick Winter
Yes, exactly!
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Sincerely,
Patrick Winter
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
