You need to install OpenEdge 10.2A 32-bit on a separate workstation and then
install the Admin Tools there.
The Admin Tools and Schema Change Tools do not work with the 64-bit version
of OpenEdge.
Section 7 of the Installation Guide.
Ned
Alternative Technology Partners
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf Of
Charles Carden
Sent: Tuesday, March 01, 2011 12:36 AM
To:
Subject: [Vantage] Upgrade from 9.04 to 9.05 error
After performing the upgrade I am getting the following error when
attempting to run any Epicor program including Schema Change and Admin
Tools:
The shared memory is version 33685504; expected 12009 (1178)
Has anyone seen this before?
I did not uninstall either OpenEdge 10.1c or Epicor 9.04.504 as the
installation of 9.05 did not indicate that I needed to. I did try once to
uninstall Epicor 9.04.504 but it failed to uninstall. Since it would
uninstall then I did not uninstall OpenEdge 10.1c either. The Admin Service
for 10.1c is disabled.
I am running Windows 2003R2 Standard 64 bit. I have installed OpenEdge
10.2a 64bit and Epicor 9.05.603. I realize the error is an OpenEdge error
but I was not able to find anything on the Progress web site that provided a
definitive answer. I also get the same error when I attempt to run Data
Administrator or Data Dictionary from the OpenEdge menu. I am able to run
PROMON under the Pro Environment and I can run Epicor Data Administration as
well. I can import a license file and add a new company to the database
without any problem.
Any help would be greatly appreciated.
Charles Carden
IT Manager
Manitex, Inc.
Georgetown, Texas
