Purchased direct checkbox on jobs
How is the checkbox “Purchased direct” populated on MRP unfirm jobs? We have a part that this flag is improperly selected, and it is not consuming available material due to that.
Unsure how that data gets populated (original source) when unfirm jobs are created through MRP.
Thanks in advance,
Gil
I believe it is the Non Stock checkbox
It can be set in a couple of places. Start with the jobs and look at the jobs that have this material in the BOM. You will want to look at the Purchasing section towards the bottom for the Purchase Direct checkbox to be checked:
You will also want to check the Non-Stock Item flags in Part Maintenance; both on the Part > Detail tab and on the Part > Sites > Detail tab:
I get that, Beth. What I am looking for is where that data is populated in Part Maintenance/Method Master. That is what drives the corresponding field in unfirm jobs, if my understanding is correct.
EDIT - Yay! For some reason, our item master was indicated “Non Stock Item”. I was looking for a flag in the method that defined the item as Purchased Direct, which was not successful.
Thank you, Beth, and Lacey. I originally missed Beth’s very clear snip of Part/Site/Detail.
Great forum here, folks.
You’re welcome Gil. Would you please mark my post as the solution? thanks!
Hi Beth,
I have this same issue but my general and site tabs are NOT marked as non-stock. What else could cause the part to automatically be checked as purchase direct in a job?
Hi Michelle,
Do you have jobs that are created from quotes? You may want to look in the quote to see if this material has been checked “Buy Direct”:
Hi Beth,
No our company does not use the quote module/transaction. They use Salesforce. It’s weird here and how little they use Epicor.
Is it possible that someone entered the part onto a sales order as purchase direct?
