I assume you are all refering to "First Article". In Job Entry, at
each operation, you can set the First Article Quantity. Vantage
canned shop warnings and global alerts then notify production and
quality when First Articles exist. The help file explains a little
more on how it is processed (as it differs if you are using MES).
Either way...because of the break quantities you may need to create
the same operation mutliple times to account for each break in qty.
In other words, if you are planning to produce 1,000 (in total) but
on every 100 you want a first article inspection...then you would
need 10 operations (100 each) and each flagged as first article for
10 pcs.
Patty Buechler
10 pcs.
Patty Buechler
--- In vantage@yahoogroups.com, "Charlie Smith" <CSmith@...> wrote:
> Yep I misread the message. And you are correct, Epicor Manufacturing
> will not handle sample programs.
> What I have done with clients in this case is to have them manually
> enter the inspection as a "first piece" record so that the sampling
can
> be entered. The first piece inspection would then be set up as one
for
> the initial notification and 1st piece process. Then when into
> production the remaining inspections are manual entries if an
inspection
> record is desired.
> The basic problem is that Epicor manufacturing not only does not
know
> the production sample plan, but there is no way of knowing when the
> sample is to be triggered unless you do some kind of quantity
recording
> through MES.
> A custom could probably be written where you could set up some
custom
> fields in the Part BOO (and in turn the Job BOO) for the sample
plan and
> then report quantities when sample quantities are hit which could
> trigger an email to inspection. Something along those lines. You
would
> still have to notify the system that the trigger quantity has been
hit
> through MES and that could get to be a problem for operations.
Behalf
> Of Robert Brown
> Sent: Sunday, December 16, 2007 11:04 AM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Question about Quality Control Module
> Charlie,
> Namish wants OP inspection triggered very 10 pc's - not just "1st
pc"
> after the intial 10 of 100 are produced.
> Vantage 8 (through 403c) doesn't support this common manufacturing
OP
> inspection pradigm.
> Another common OP inspection paradigm unsupported is to trigger in
> process OP inspections on a routine time schedule such as 1st pc at
> shift start, mid-day inspection and (in the case of pallet loaded
or bar
> fed CNC equipment that will continue to run unattended after the
shift
> ends) end of shift inspection.
> Epicor would be wise to work on supporting this in the future as,
> frankly, their current Inspection/DMR processing is anemic.
> We may tackle supporting these more realistic paradigm's in the
future
> via customization. Until then, all our customizations are focused
upon
> gaping critical holes in Vantage (and we can handle the OP
inspections
> offline).
> Rob Brown
> Charlie Smith <CSmith@...
> <mailto:CSmith%40vistaconsultant.com> > wrote:
> Set up the expected 10 pieces in your milling operation as the first
> piece quantity. When you log into the operation under setup, the
> inspection will show up on the inspection panel within QC. Run the
10
> pieces under setup. Once approved by inspection, you can run the
other
> 90 under production.
> Charlie Smith
> 2W Technologies LLC
> www.2WTech.com <http://www.2WTech.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%
40yahoogroups.com> ] On
> Behalf
> Of nimish_bhatia1
> Sent: Saturday, December 15, 2007 9:28 PM
> Subject: [Vantage] Question about Quality Control Module
> I have a simple question about how to setup the system so that the
> material is inspected after a each batch of units is completed. For
> instance, if we are doing a milling operation on 100 units, can we
> setup the system in such a way that after each 10 units are finished
> with the milling process, an inspection needs to be carried out by
the
> Quality Control team? I was told by our implementation company that
> they would also look into this. They initially thought that it is
> only possible to do a quality check after each process is complete.
> In our case, milling may be the only operation and we don't want to
> wait until all the 100 pieces are completed with milling to do a
> quality check.
> Never miss a thing. Make Yahoo your homepage.
