Hello Jim,
No, we never got queue times to reflect in the due dates for operations. The last we discussed on this was that I would need to upgrade in order to get MRP working correctly (something echoed by Rob in response to this question). Unfortunately, an upgrade takes time and I was hoping for a workaround to assist in scheduling until then.
Tim
Tim
--- In vantage@yahoogroups.com, "Jim Chance" <jim_chance@...> wrote:
> Tim, I thought I provided you an answer on this when I demonstrated the
> queue times for you.
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> sci.thollingsworth
> Sent: Tuesday, April 02, 2013 4:51 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Queue Time in Between ops on same WC
> Hello,
> Did anyone ever get a good answer on this? This is causing me big problems,
> Tim
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "bbelzer42" <bbelzer@> wrote:
> > In 6.10 I am starting to change what my default queue times are for
> > each workcenter. What I am trying to achieve is a gap in between jobs
> > at a particular work center.
> > For example at Work Center 200 (Lathe) I want an hour in between when
> > one job finished and another starts.
> > I put a queue time of 30 min and a move time of 30 min. Then I did
> > Load Leveling.
> > Instead of a gap between jobs, it has the queue time of Job 2 overlap
> > with the end of Job 1 so there is no gap in between operations.
> > How can I achieve what I am looking for? I thought thats what the
> > queue time was for?
> > Thanks in advance!!
> > Ben
