Thanks to everyone for your patience and in-depth responses.
I've passed along your suggestions to an outside firm that gives us IT
support and hopefully they'll be able to make this work for us.
Again - my deepest thanks to everyone.
Tricia
_____
Nick
Sent: Monday, April 11, 2011 1:11 PM
Subject: Re: [Vantage] Remote Printing/Terminal Services
Mark,
We currently have just a terminal server. So i guess that answers your first
question. Zac is correct that no matter how you set it up, if you are coming
in over a TS session, the drivers need to be installed on the host machine
prior to the connection. And Zac is also correct in that remote printing is
a pain in the butt. It has gotten much easier with server 2008 vs server
2000...but it still isnt the greatest. Also, MFP's are pretty much not
supported.
Tricia has basically 3 options.
1. Straight VPN. Setup VPN's for all remote clients. I do not reccomend this
option since I have no clue what AV software is on the clients and have no
idea what the security is like on them. This is a bad option. But setting up
a printer is much easier since it makes it look like the computer is
connected to the company LAN just like normal. This can be confusing for
people who dont know much about computers because they dont understand that
they need to be on the VPN first.
2. TS over VPN. Kinda what she is doing now. But I would never have a user
anywhere connect directly to my servers. Have a workstation in front or a
designated terminal server server. I dont want to clutter up my servers with
other user profiles and such. More overhead though since you need to
maintain the VPN session first and then an TS session. Same rules apply with
adding printers over a TS session. Gotta add them to the host first. This
is VERY confusing to the end users. We had this for people who were
traveling. I got calls EVERY TIME!
3. TS Gateway. If i am at home, i can connect directly to my work
computer(as long as its turned on) and work from it. This is advantageous
for my situation because I have access to all of my docs, my hard drive and
my personal items. You still need to add the printers with the same rules as
the TS over VPN, however, you only need to add 1 printer vs if you had a TS
server, you would have to add many printers for all of the remote users.
From experience, this is easy for end users. I wrote up a simple document
and have it ready for all of them as they are traveling and I dont think I
have gotten one call since this went into effect(about 2 months ago). I
tested it on my workstation first about 6 months ago after learning about it
from a friend of mine.
Also, Zac is also correct, you need an SSL certificate.
On Mon, 11 Apr 2011 09:38:46 -0400
Mark Wonsil <mark_wonsil@... <mailto:mark_wonsil%40yahoo.com> > wrote:
Nick wrote:
are they
using a TS desktop? It would seem that the TS App would
give Tricia
and others the remote printing and cut down on some of
the overhead as
well as be more secure than a straight VPN - if I
correctly understand
how it works.
Mark W.
Tricia
_____
Nick
Mark,
supported.
Nick wrote:
> I love a new feature of Windows 2008. Terminal ServerNick, have you set up Epicor as a Terminal Server App or
>Gateway. It hands off
> the RDP session to whatever computer you want. This way
>you only have to
> poke a single hole in your router, and for security, you
>can control which
> users have access to which computers a lil more easily.
>It has the same
> limitations as what Zac was just menioning, its just
>another way of doing
> things. Learned of the new feature about 6 months ago and
>IMO, it rocks. I
> used to just change the RDP listening port on every
>computer individually.
are they
give Tricia
the overhead as
how it works.
Mark W.
