Rename a Customer Document
We have a large number of customers using EDI and all but one of them, the ASN CustomerDocs.DocumentName is “EDI-856”, we have one customer that was apparently created wrong as “EDI-865” (with the 6 and 5 reversed, took me an embarrassing long time to figure that out).
Anyway, that is causing this customer to be filtered out of one of our KPI reports looking for missing or unsent/unack’d ASNs. Epicor does not let us edit this field or delete the record. Is there anyway to correct this field?
And a less official, is this field used anywhere else in Epicor for relational data, I know I don’t use it in any other location, but does Epicor that any one knows of?
You should be able to make an ubaq with an advanced update to fix the 865 to 856 or you could just adapt the kpi report to find the bad ack.
