Replace backflushed Material in existing Jobs. 905.606.A
You can Return Material under Inventory Management > General Operations for the material not needed.
When you do – click the Issue Complete checkbox.
Add the new materials to the job and Issue Material under Inventory Management > General Operations.
Also – doing the personalization or customization as mentioned in a prior post and unhiding the Issue Complete is a good idea.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jacqueline Restivo
Sent: Wednesday, April 09, 2014 8:38 AM
Subject: Re: [Vantage] Replace backflushed Material in existing Jobs. 905.606.A
These are active jobs, need to replace material 1/2 way through completeing qty.
Guess closing the existing job and opening a new job would be the other way.
Thanks josh.
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Wednesday, April 9, 2014 11:34 AM
Subject: RE: [Vantage] Replace backflushed Material in existing Jobs. 905.606.A
I am guessing these are jobs that were completed with the incorrect materials being backflushed. If you reverse the labor quantity it should pull the material off, you could then change the part number on your job and re-enter the labor quantity to have that material backflushed. The other way that I know of would be to manually return the material, change the part number, and manually issue the material.
Josh Serwe
Wisconsin Converting Inc.
Production Planning
(920)437-6400 x 327
Sent: Wednesday, April 09, 2014 10:18 AM
Subject: [Vantage] Replace backflushed Material in existing Jobs. 905.606.A
Good day all,
I'm trying to replace material on an existing job. It won't allow me to 0 the qty on the original material so it stops pulling from inventory.
Is there a way or is it a manual transfer?
Thanks in advance
jacqueline
Good day all,
Thanks in advance
jacqueline
Josh Serwe
Production Planning
(920)437-6400 x 327
Good day all,
Thanks in advance
jacqueline
You can mark the material issued complete in job entry, so it won’t issue that material. Do a personalization on the material list collection to unhide the issued complete checkbox.
Sent: Wednesday, April 09, 2014 11:18 AM
Good day all,
Thanks in advance
jacqueline
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
Thanks josh.
Josh Serwe
Production Planning
(920)437-6400 x 327
Good day all,
Thanks in advance
jacqueline
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384 -- #ygrps-yiv-149121059yiv1971005384ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-mkp #ygrps-yiv-149121059yiv1971005384hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-mkp #ygrps-yiv-149121059yiv1971005384ads {
margin-bottom:10px;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-mkp .ygrps-yiv-149121059yiv1971005384ad {
padding:0 0;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-mkp .ygrps-yiv-149121059yiv1971005384ad p {
margin:0;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-mkp .ygrps-yiv-149121059yiv1971005384ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-sponsor #ygrps-yiv-149121059yiv1971005384ygrp-lc {
font-family:Arial;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-sponsor #ygrps-yiv-149121059yiv1971005384ygrp-lc #ygrps-yiv-149121059yiv1971005384hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-sponsor #ygrps-yiv-149121059yiv1971005384ygrp-lc .ygrps-yiv-149121059yiv1971005384ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384activity span {
font-weight:700;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384activity span span {
color:#ff7900;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384activity span .ygrps-yiv-149121059yiv1971005384underline {
text-decoration:underline;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 .ygrps-yiv-149121059yiv1971005384attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 .ygrps-yiv-149121059yiv1971005384attach div a {
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 .ygrps-yiv-149121059yiv1971005384attach img {
border:none;padding-right:5px;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 .ygrps-yiv-149121059yiv1971005384attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 .ygrps-yiv-149121059yiv1971005384attach label a {
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 .ygrps-yiv-149121059yiv1971005384bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 .ygrps-yiv-149121059yiv1971005384bold a {
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 dd.ygrps-yiv-149121059yiv1971005384last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 dd.ygrps-yiv-149121059yiv1971005384last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 dd.ygrps-yiv-149121059yiv1971005384last p span.ygrps-yiv-149121059yiv1971005384yshortcuts {
margin-right:0;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 div.ygrps-yiv-149121059yiv1971005384attach-table div div a {
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 div.ygrps-yiv-149121059yiv1971005384attach-table {
width:400px;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 div.ygrps-yiv-149121059yiv1971005384file-title a, #ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 div.ygrps-yiv-149121059yiv1971005384file-title a:active, #ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 div.ygrps-yiv-149121059yiv1971005384file-title a:hover, #ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 div.ygrps-yiv-149121059yiv1971005384file-title a:visited {
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 div.ygrps-yiv-149121059yiv1971005384photo-title a, #ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 div.ygrps-yiv-149121059yiv1971005384photo-title a:active, #ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 div.ygrps-yiv-149121059yiv1971005384photo-title a:hover, #ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 div.ygrps-yiv-149121059yiv1971005384photo-title a:visited {
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 div#ygrps-yiv-149121059yiv1971005384ygrp-mlmsg #ygrps-yiv-149121059yiv1971005384ygrp-msg p a span.ygrps-yiv-149121059yiv1971005384yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 .ygrps-yiv-149121059yiv1971005384green {
color:#628c2a;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 .ygrps-yiv-149121059yiv1971005384MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 o {
font-size:0;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384photos div {
float:left;width:72px;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384reco-category {
font-size:77%;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384reco-desc {
font-size:77%;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 .ygrps-yiv-149121059yiv1971005384replbq {
margin:4px;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-mlmsg select, #ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 input, #ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-mlmsg pre, #ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 code {
font:115% monospace;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-mlmsg #ygrps-yiv-149121059yiv1971005384logo {
padding-bottom:10px;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-msg p#ygrps-yiv-149121059yiv1971005384attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-reco #ygrps-yiv-149121059yiv1971005384reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-sponsor #ygrps-yiv-149121059yiv1971005384ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-sponsor #ygrps-yiv-149121059yiv1971005384ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-sponsor #ygrps-yiv-149121059yiv1971005384ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-text {
font-family:Georgia;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-text tt {
font-size:120%;}
#ygrps-yiv-149121059 #ygrps-yiv-149121059yiv1971005384 #ygrps-yiv-149121059yiv1971005384ygrp-vital ul li:last-child {
border-right:none !important;}
