A Question
Carl
You can use the Material Return function or the salvage function.
Material issue is part of Issues/Returns. Salvage is part of Receipts
from MFG.
Russ Dover
To: <vantage@yahoogroups.com>
Subject: [Vantage] A Question
> Situation: Job Traveler was released in early July and all materials
> listed in job traveler have already been back-flushed after kitting.
> Back flush occurred a day after release.
> Problem: After the backflush was completed. A new material was
> ordered to
> replace an existing part listed on the current (released) job
> traveler.
> In the actual floor event- the existing part was
> removed from the job and the new material was instead used.
> Process; How do you delete the material listed in Job Traveler and
> add the
> new material after all materials have been backflushed.
> In this situation the job is still open.
> Problems encountered: Vantage 6.0 will not allow deletion of any
> material
> if the job has been backflushed and transactions posted by accounting.
> How do you solve this?
> Carl Heeder
> ST Inverter America
> 281-506-3146
> Mobile: 281-221-3421
> FAX 978-725-3057
> must have already linked your email address to a yahoo id to enable
> access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> YAHOO! GROUPS LINKS
> * Visit your group "vantage" on the web.
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Problem: After the backflush was completed. A new material was ordered to
replace an existing part listed on the current (released) job traveler.
Process; How do you delete the material listed in Job Traveler and add the
Problems encountered: Vantage 6.0 will not allow deletion of any material
Carl Heeder
ST Inverter America
281-506-3146
FAX 978-725-3057
Would it work to use the negative qty "issue to job", but mark the material
complete at the same time?
The material will still show on the job requirement, with the activity
history, but it will also show complete so Vantage wont keep trying to fill
it.
this is just a thought. We're not on 6.0 yet, but we "un-issue" materials
on occasion for similar reasons. At that time a memo is added to explain
what happened to that bad boy.
Rhonda
Sent: Tuesday, August 02, 2005 3:59 PM
Carl Heeder
ST Inverter America
281-506-3146
FAX 978-725-3057
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage <http://groups.yahoo.com/group/vantage> "
on the web.
_____
