Right-Click into Tracker .dll not valid for user
I just added a new MenuID to the PROCESS section using the right DLL and it all started  “automagially” working. Easy fix.
Joshua Giese
CIO
Direct:     920.593.8299
IT Dept:   920.437.6400 Ext. 337
Site ID:    27450-E905702A-SQL64
Wisconsin Converting, Inc.
Sent: Friday, March 13, 2015 3:10 PM
Subject: RE: [Vantage] Right-Click into Tracker .dll not valid for user
That is EPICORs fix. I had that issue on 702A.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Friday, March 13, 2015 11:32 AM
I tried launching the screen as its own standalone menu, but not as a process call I’ll give that a shot why not.
Joshua Giese
CIO
Sent: Friday, March 13, 2015 11:29 AM
We resolved it by adding a process in Menu Maintenance.  It seems like the tracker doesn’t exist in the menu so you have to add it as a separate custom menu process to find the .dll.  Try creating a new process in menu maintenance and selecting the .dll in question.
Sent: Friday, March 13, 2015 11:23 AM
We have the same issue I never got a response from Epicor
Joshua Giese
CIO
Sent: Friday, March 13, 2015 10:49 AM
Subject: [Vantage] Right-Click into Tracker .dll not valid for user
In Supplier Tracker, when we do a right-click into the Invoice number to open up the GL Transaction Detail Tracker, we are getting a menu access error where the .dll is not valid for the current user.  Is this a user security set up issue?  I can’t seem to find it on the menu tree to access the GL Tran Detail Tracker to test.
<!-- #ygrps-yiv-263247974 _filtered #ygrps-yiv-263247974 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-263247974 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-263247974 {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #ygrps-yiv-263247974 {font-family:Consolas; panose-1:2 11 6 9 2 2 4 3 2 4;} _filtered #ygrps-yiv-263247974 {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4;} #ygrps-yiv-263247974 #ygrps-yiv-263247974 p.ygrps-yiv-263247974MsoNormal, #ygrps-yiv-263247974 li.ygrps-yiv-263247974MsoNormal, #ygrps-yiv-263247974 div.ygrps-yiv-263247974MsoNormal {margin:0in; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman", "serif";} #ygrps-yiv-263247974 a:link, #ygrps-yiv-263247974 span.ygrps-yiv-263247974MsoHyperlink { color:blue; text-decoration:underline;} #ygrps-yiv-263247974 a:visited, #ygrps-yiv-263247974 span.ygrps-yiv-263247974MsoHyperlinkFollowed { color:purple; text-decoration:underline;} #ygrps-yiv-263247974 p {
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-263247974 code
font-family:“Courier New”;}
#ygrps-yiv-263247974 pre
margin:0in;
font-size:10.0pt;
#ygrps-yiv-263247974 tt
#ygrps-yiv-263247974 span.ygrps-yiv-263247974cat
#ygrps-yiv-263247974 span.ygrps-yiv-263247974ct
#ygrps-yiv-263247974 span.ygrps-yiv-263247974HTMLPreformattedChar
font-family:Consolas;}
#ygrps-yiv-263247974 p.ygrps-yiv-263247974attach, #ygrps-yiv-263247974 li.ygrps-yiv-263247974attach, #ygrps-yiv-263247974 div.ygrps-yiv-263247974attach
margin-right:0in;
margin-left:0in;
font-size:9.0pt;
font-family:“Arial”, “sans-serif”;}
#ygrps-yiv-263247974 p.ygrps-yiv-263247974bold, #ygrps-yiv-263247974 li.ygrps-yiv-263247974bold, #ygrps-yiv-263247974 div.ygrps-yiv-263247974bold
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
font-weight:bold;}
#ygrps-yiv-263247974 p.ygrps-yiv-263247974green, #ygrps-yiv-263247974 li.ygrps-yiv-263247974green, #ygrps-yiv-263247974 div.ygrps-yiv-263247974green
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
color:#628C2A;}
#ygrps-yiv-263247974 p.ygrps-yiv-263247974replbq, #ygrps-yiv-263247974 li.ygrps-yiv-263247974replbq, #ygrps-yiv-263247974 div.ygrps-yiv-263247974replbq
margin:3.0pt;
font-size:12.0pt;
#ygrps-yiv-263247974 p.ygrps-yiv-263247974ad, #ygrps-yiv-263247974 li.ygrps-yiv-263247974ad, #ygrps-yiv-263247974 div.ygrps-yiv-263247974ad
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-263247974 p.ygrps-yiv-263247974underline, #ygrps-yiv-263247974 li.ygrps-yiv-263247974underline, #ygrps-yiv-263247974 div.ygrps-yiv-263247974underline
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-263247974 span.ygrps-yiv-263247974yshortcuts
#ygrps-yiv-263247974 p.ygrps-yiv-263247974ad1, #ygrps-yiv-263247974 li.ygrps-yiv-263247974ad1, #ygrps-yiv-263247974 div.ygrps-yiv-263247974ad1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-263247974 p.ygrps-yiv-263247974ad2, #ygrps-yiv-263247974 li.ygrps-yiv-263247974ad2, #ygrps-yiv-263247974 div.ygrps-yiv-263247974ad2
margin-right:0in;
margin-bottom:7.5pt;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-263247974 p.ygrps-yiv-263247974underline1, #ygrps-yiv-263247974 li.ygrps-yiv-263247974underline1, #ygrps-yiv-263247974 div.ygrps-yiv-263247974underline1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-263247974 span.ygrps-yiv-263247974yshortcuts1
font-family:“Verdana”, “sans-serif”;
font-weight:bold;}
#ygrps-yiv-263247974 span.ygrps-yiv-263247974yshortcuts2
font-weight:normal;}
#ygrps-yiv-263247974 span.ygrps-yiv-263247974EmailStyle36
font-family:“Calibri”, “sans-serif”;
color:#1F497D;}
#ygrps-yiv-263247974 .ygrps-yiv-263247974MsoChpDefault
font-size:10.0pt;}
margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-263247974 div.ygrps-yiv-263247974WordSection1
font-family:Symbol;}
font-family:Wingdings;}
#ygrps-yiv-263247974 ol
{margin-bottom:0in;}
#ygrps-yiv-263247974 ul
Joshua Giese
CIO
Joshua Giese
CIO
Joshua Giese
CIO
Miguel A. Santillan
Joshua Giese
CIO
Joshua Giese
CIO
