Mark, Jitterbit looks really interesting and a lot like Service
Connect. I'm assuming that it supports the WS-* authentication
protocols that the Epicor web services use? I'm fuzzy on how all of
this fits together though. I'd like to play with it and see if I could
get it to similar things to SC, but can't imagine when I'd have time.
I agree that the biggest problem with the web services is the lack of
documentation, and according to David Weiseth from Epicor there likely
will never be one. Their own approach is basically experience based on
trial and error.
-brian
Of Mark Wonsil
Sent: Tuesday, September 23, 2008 4:51 PM
Subject: RE: [Vantage] Re: Service Connect or a Cheaper Way?
I completely agree with Brian here. If you're using the Web
Services/Business Objects then you shouldn't see any data corruption.
But
like Brian notes, you can get unexpected results! If you run the .Delete
method, it will try to delete something.
Back to the question, has anyone tried any other web service
choreographer
package instead of ServiceConnect? Shouldn't BizTalk[1] server be able
to
communicate directly with the Epicor Web Services? There is also an open
source integration platform called JitterBit[2], which sports a free
version. Only one of these may be considered a "cheaper" way.
It seems to me however that the real "fun" in dealing with web services
is
figuring out the calling sequence, parameters, and error reporting in a
trial and error fashion. While one can trace calls, it sure would be
helpful
if there was some documentation.
trial and error.
-brian
Of Mark Wonsil
But
choreographer
to
is
helpful
