I've seen this happen, but it has been random and not associated with any one PC or login. Most of the time, you can right click on the System Monitor in the task tray and select exit which will shut down the session. In extreme cases I've had to do a ctrl-alt-del and kill the session, sometimes more then once. Never have found what causes it.
If it is happening to one PC all the time, I would suspect a driver or process outside of Vantage hanging it up. Maybe even spyware.
To: Vantage User Group <vantage@yahoogroups.com>
Sent: Tue, November 17, 2009 4:24:00 PM
Subject: [Vantage] Session not closing
Â
We are experiencing a problem with one pc where the Vantage session hangs at the end of the day and will not close. We end up shutting the pc down and manually canceling the session. We are running 803.408A. Has anyone else experienced this? If so, what did you determine was causing it to happen?
Â
