find your .mfgsys file and open it with notepad...... mine is found in c/:epicor/epicor905/client/config.
search for sign and change false to true......
<SingleSignOn value="false" bool="" />
That’s only the case if you setup their profile and check the box labeled “Require Single Sign-on†on the user settings screen.
If you don’t check that box then they can still maintain a username and password and sign on from any computer, regardless of the windows logon at that workstation.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of neverunmacron@...
Sent: Wednesday, February 12, 2014 12:38 PM
Subject: [Vantage] RE: Single Sign on
Single sign on means that the person can online sign on to vantage when he or she is signed on to the netowrk on that computer. he or she cannot open vantage under their name from someones else pc
----- Original Message -----From: NedSent: Wednesday, February 12, 2014 11:40 AMSubject: RE: [Vantage] RE: Single Sign on
----- Original Message -----From: Karen SchoenungSent: Wednesday, February 12, 2014 3:13 PMSubject: RE: [Vantage] RE: Single Sign on
Have you set the password for the Epicor user to the same one as the windows logon?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Charles Carden
Sent: Wednesday, February 12, 2014 2:36 PM
Subject: Re: [Vantage] RE: Single Sign on
According to everyone that responded all I should have to do is enter the domain userid and the login domain in the user record and enter true for the SingleSignOn value in the .mfgsys file. Everytime I try this I get an error message that reads "You are not setup for single sign on".
Any other suggestions that might help?
Charles Carden
On Wed, Feb 12, 2014 at 4:00 PM, Charles Carden <shadowcar1449@…> wrote:<div> <p><u></u>
Yes I have.Charles CardenSent: Wednesday, February 12, 2014 3:13 PMSubject: RE: [Vantage] RE: Single Sign on
Charles Carden
That’s only the case if you setup their profile and check the box labeled “Require Single Sign-on” on the user settings screen.
Single sign on means that the person can online sign on to vantage when he or she is signed on to the netowrk on that computer. he or she cannot open vantage under their name from someones else pc</div> <div style="color:#fff;min-height:0;"></div>
<div id="ygrps-yiv-1637899104yiv1557152808ygrp-text">
<div></div><div class="ygrps-yiv-1637899104yiv1557152808WordSection1"><div class="ygrps-yiv-1637899104yiv1557152808MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">That’s only the case if you setup their profile and check the box labeled “Require Single Sign-on†on the user settings screen.</span></div><div class="ygrps-yiv-1637899104yiv1557152808MsoNormal"><span style="font-size:11.0pt;color:#1F497D;"> </span></div><div class="ygrps-yiv-1637899104yiv1557152808MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">If you don’t check that box then they can still maintain a username and password and sign on from any computer, regardless of the windows logon at that workstation.</span></div><div class="ygrps-yiv-1637899104yiv1557152808MsoNormal"><span style="font-size:11.0pt;color:#1F497D;"> </span></div><div class="ygrps-yiv-1637899104yiv1557152808yqt4914934994" id="ygrps-yiv-1637899104yiv1557152808yqt41455"><div><div style="border-top:solid #B5C4DF 1.0pt;"><div class="ygrps-yiv-1637899104yiv1557152808MsoNormal"><b><span style="font-size:10.0pt;">From:</span></b><span style="font-size:10.0pt;"> vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] <b>On Behalf Of </b>neverunmacron@...<br clear="none"><b>Sent:</b> Wednesday, February 12, 2014 12:38 PM<br clear="none"><b>To:</b> vantage@yahoogroups.com<br clear="none"><b>Subject:</b> [Vantage] RE: Single Sign on</span></div></div></div><div class="ygrps-yiv-1637899104yiv1557152808MsoNormal"> </div><div class="ygrps-yiv-1637899104yiv1557152808MsoNormal"><br clear="none"><br clear="none">Single sign on means that the person can online sign on to vantage when he or she is signed on to the netowrk on that computer. he or she cannot open vantage under their name from someones else pc <br clear="none"><br clear="none"><br clear="none"></div></div><div><div class="ygrps-yiv-1637899104yiv1557152808MsoNormal"><span style="color:white;"></span></div></div></div>
</div>
<div class="ygrps-yiv-1637899104yiv1557152808yqt4914934994" id="ygrps-yiv-1637899104yiv1557152808yqt62968"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-mkp #ygrps-yiv-1637899104yiv1557152808hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-mkp #ygrps-yiv-1637899104yiv1557152808ads {
margin-bottom:10px;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-mkp .ygrps-yiv-1637899104yiv1557152808ad {
padding:0 0;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-mkp .ygrps-yiv-1637899104yiv1557152808ad p {
margin:0;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-mkp .ygrps-yiv-1637899104yiv1557152808ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-sponsor #ygrps-yiv-1637899104yiv1557152808ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-sponsor #ygrps-yiv-1637899104yiv1557152808ygrp-lc #ygrps-yiv-1637899104yiv1557152808hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-sponsor #ygrps-yiv-1637899104yiv1557152808ygrp-lc .ygrps-yiv-1637899104yiv1557152808ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808activity span {
font-weight:700;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808activity span span {
color:#ff7900;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808activity span .ygrps-yiv-1637899104yiv1557152808underline {
text-decoration:underline;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 .ygrps-yiv-1637899104yiv1557152808attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 .ygrps-yiv-1637899104yiv1557152808attach div a {
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 .ygrps-yiv-1637899104yiv1557152808attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 .ygrps-yiv-1637899104yiv1557152808attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 .ygrps-yiv-1637899104yiv1557152808attach label a {
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 .ygrps-yiv-1637899104yiv1557152808bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 .ygrps-yiv-1637899104yiv1557152808bold a {
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 dd.ygrps-yiv-1637899104yiv1557152808last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 dd.ygrps-yiv-1637899104yiv1557152808last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 dd.ygrps-yiv-1637899104yiv1557152808last p span.ygrps-yiv-1637899104yiv1557152808yshortcuts {
margin-right:0;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 div.ygrps-yiv-1637899104yiv1557152808attach-table div div a {
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 div.ygrps-yiv-1637899104yiv1557152808attach-table {
width:400px;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 div.ygrps-yiv-1637899104yiv1557152808file-title a, #ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 div.ygrps-yiv-1637899104yiv1557152808file-title a:active, #ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 div.ygrps-yiv-1637899104yiv1557152808file-title a:hover, #ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 div.ygrps-yiv-1637899104yiv1557152808file-title a:visited {
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 div.ygrps-yiv-1637899104yiv1557152808photo-title a, #ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 div.ygrps-yiv-1637899104yiv1557152808photo-title a:active, #ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 div.ygrps-yiv-1637899104yiv1557152808photo-title a:hover, #ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 div.ygrps-yiv-1637899104yiv1557152808photo-title a:visited {
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 div#ygrps-yiv-1637899104yiv1557152808ygrp-mlmsg #ygrps-yiv-1637899104yiv1557152808ygrp-msg p a span.ygrps-yiv-1637899104yiv1557152808yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 .ygrps-yiv-1637899104yiv1557152808green {
color:#628c2a;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 .ygrps-yiv-1637899104yiv1557152808MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 o {
font-size:0;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808photos div {
float:left;width:72px;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808reco-category {
font-size:77%;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808reco-desc {
font-size:77%;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 .ygrps-yiv-1637899104yiv1557152808replbq {
margin:4px;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-mlmsg select, #ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 input, #ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-mlmsg pre, #ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 code {
font:115% monospace;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-mlmsg #ygrps-yiv-1637899104yiv1557152808logo {
padding-bottom:10px;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-msg p#ygrps-yiv-1637899104yiv1557152808attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-reco #ygrps-yiv-1637899104yiv1557152808reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-sponsor #ygrps-yiv-1637899104yiv1557152808ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-sponsor #ygrps-yiv-1637899104yiv1557152808ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-sponsor #ygrps-yiv-1637899104yiv1557152808ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1637899104 #ygrps-yiv-1637899104yiv1557152808 #ygrps-yiv-1637899104yiv1557152808ygrp-vital ul li:last-child {
border-right:none !important;}
