Single Sign On Blank Title 62173
<html
#ygrps-yiv-983901352 .ygrps-yiv-983901352ygrp-photo-title { TEXT-ALIGN:center;WIDTH:75px;HEIGHT:15px;CLEAR:both;FONT-SIZE:smaller;OVERFLOW:hidden;} #ygrps-yiv-983901352 DIV.ygrps-yiv-983901352ygrp-photo { BORDER-BOTTOM:black 1px solid;BORDER-LEFT:black 1px solid;BACKGROUND-COLOR:white;WIDTH:62px;BACKGROUND-REPEAT:no-repeat;BACKGROUND-POSITION:center 50%;HEIGHT:62px;BORDER-TOP:black 1px solid;BORDER-RIGHT:black 1px solid;} #ygrps-yiv-983901352 DIV.ygrps-yiv-983901352photo-title A { TEXT-DECORATION:none;} #ygrps-yiv-983901352 DIV.ygrps-yiv-983901352photo-title A:active { TEXT-DECORATION:none;} #ygrps-yiv-983901352 DIV.ygrps-yiv-983901352photo-title A:hover { TEXT-DECORATION:none;} #ygrps-yiv-983901352 DIV.ygrps-yiv-983901352photo-title A:visited { TEXT-DECORATION:none;} #ygrps-yiv-983901352 DIV.ygrps-yiv-983901352attach-table DIV.ygrps-yiv-983901352attach-row { CLEAR:both;} #ygrps-yiv-983901352 DIV.ygrps-yiv-983901352attach-table DIV.ygrps-yiv-983901352attach-row DIV { FLOAT:left;} #ygrps-yiv-983901352 P { PADDING-BOTTOM:3px;PADDING-LEFT:0px;PADDING-RIGHT:0px;CLEAR:both;OVERFLOW:hidden;PADDING-TOP:15px;} #ygrps-yiv-983901352 DIV.ygrps-yiv-983901352ygrp-file { WIDTH:30px;} #ygrps-yiv-983901352 DIV.ygrps-yiv-983901352attach-table DIV.ygrps-yiv-983901352attach-row DIV DIV A { TEXT-DECORATION:none;} #ygrps-yiv-983901352 DIV.ygrps-yiv-983901352attach-table DIV.ygrps-yiv-983901352attach-row DIV DIV SPAN { FONT-WEIGHT:normal;} #ygrps-yiv-983901352 DIV.ygrps-yiv-983901352ygrp-file-title { FONT-WEIGHT:bold;}
You have to leave off the .com in Epicor for the Domain.
----- Original Message -----
Sent: Wednesday, February 12, 2014 7:11 AM
Subject: RE: [Vantage] Single Sign On
1 – Add Domain and Domain Username to a user’s record.
2- Edit the .mfgsys config file for the client from <singlesignon value=”false” bool=”” />  to <singlesignon value=”true” bool=”” />
That should take care of it for you.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Charles Carden
Sent: Wednesday, February 12, 2014 9:58 AM
Subject: [Vantage] Single Sign On
I suppose I do not understand how single sign on works as I have not been able to get it to.  Would someone please explain the steps necessary to get single sign on to work.  We are on 9.05.702a although I don't think that makes any difference in the setup procedures.
 Thank you.
Charles Carden
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2014.0.4259 / Virus Database: 3697/7086 - Release Date: 02/12/14
We have our active directory setup so that our users must change their
passwords every 90 days. Apparently, Vantage does not see this change.
Do we honestly have to zero out everyone's password each time they
change their windows password, so that they stay matched? Are there any
other options other than removing the 90-day password change?
Matt Caldwell
Technical Support Analyst
KERUSSO
P.O. Box 32
Berryville, AR 72616
Phone: 800-424-0943 Ext. 231
Fax: 870-423-3568
Web Site: http://www.kerusso.com
CONFIDENTIALITY STATEMENT:
This message, from Kerusso Inc., contains information
which is privileged and confidential and is solely for the use of
the intended recipient. If you are not the intended recipient, be
aware that any review, disclosure, copying, distribution, or use
of the contents of this message is strictly prohibited. If you have
received this in error, please destroy it and notify us immediately
at: 800-424-0943
We are on Vantage 6.1 and the user can change the Vantage password by clicking on "options" and then "change password".
Our users normally have a different user and password for Vantage vs the domain logon.
FYI
Paul Lipham
Alabama Specialty Products, Inc.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Matt Caldwell
Sent: Monday, January 28, 2008 8:52 AM
Matt Caldwell
KERUSSO
P.O. Box 32
Fax: 870-423-3568
at: 800-424-0943
I'm not 100 % sure, but I believe that the single sign on feature
effectively eliminates the password checking. Instead it makes the
assumption that if your domain username (on the PC your running
Vantage from)is authenticated by the domain controller, then no
password check is performed.
The Epicor support docs for single sign on are pretty sketchy. There
are several settings, that kind of work together. They are:
1) The "Domain", "Domain UserID", and "Require Single Sign On" fields
in the "User Security" window.
2) The "Require Single Sign On" check box on the "User" tab in
the "ConfigEditor" utility program.
3) The "UserID & UserPassword" textboxes on the "User" tab in
The ConfigEditor program is in the client folder on the client PC
(mine is in C:\client803\client). And for whatever reason, the
ConfigEditor program always starts up minimized. So look in the
Windows task bar, after you've double clicked it.
If I setup the Users settings(from #1 above), set the Require Single
Sign On check box (from #2 above), and leave the items from #3 blank
it seems to work.
Calvin
their
change.
there any
> Matt Caldwell
> KERUSSO
> P.O. Box 32
> Fax: 870-423-3568
> at: 800-424-0943
First, you need to understand the EPICOR definition of Single Sign-on
is not the traditional definition. They mean...when you check the
Single Sign-on box, you can open up on 1 single session of Vantage
for that user-id.
When starting the Vantage application, you will always be required to
somehow enter the User ID / Password established in the Vantage
security model. To ease this process for the user, you get
Vantage "cut and paste" the UI from the Windows client, or you can
create, either an INI file for Registry entry (I can't remember which
one) to hold this information which will then allow the user to start
up automatically. In either case, passwords are stored in plain text
and are in no way integrated with MS Active Directory. So if your
domain PW changes, you have to change to Vantage PW manually to keep
them in synch.
We understand EPICOR is planning to MS AD integration for Version 9.0
but don't be fooled now, it does not exist.
There
fields
Single
blank
> it seems to work.
> Calvin
> their
> change.
> there any
> > Matt Caldwell
> > KERUSSO
> > P.O. Box 32
> > Fax: 870-423-3568
have
immediately
> > at: 800-424-0943
(Sorry if you got this twice. I deleted the first one right after I
realized the chart I entered was all reformated)
Epicor's definition of Single Sign On(SSO) is...
"Single Sign-On (SSO) is functionality that allows users to sign on
(log in) to Vista using the Login IDs and Passwords they use to log
into their computer's operating system (for example Windows, Unix,
Linux and so on). In other words, if SSO is enabled, users will not
be presented with a Logon window when they click their Vista icon;
they will be taken directly to the application's main menu."
It does not limit the user to a single session. With SSO enabled, I
can launch two (or more) sessions.
Some important notes about SSO.
Vantage User Setting = False
PC Config File Setting = False
User is prompted for userID and password
PC Config File Setting = True
User is automatically logged into Vantage with the userid that they
are logged into the PC with. User can switch to another user's ID
once Vantage is loaded.
Vantage User Setting = True
User is presented with login window, but will not be allowed to
login. Only users WITHOUT SSO enabled can login from this PC.
User is automatically logged into Vantage. User can switch to
another user's ID once Vantage is loaded.
Vantage never needs its password to match the domain password. Or
even be entered anywhere.
Calvin
on
> for that user-id.
to
which
start
text
keep
> them in synch.
9.0
feature
the
> There
> fields
PC
> Single
> blank
> > it seems to work.
> > Calvin
change
> > their
this
> > change.
they
> > there any
> > > Matt Caldwell
> > > KERUSSO
> > > P.O. Box 32
> > > Fax: 870-423-3568
of
be
use
> have
> immediately
> > > at: 800-424-0943
Ok, so back to an earlier statement in this thread...
Can someone please confirm if the password is stored in plain text somewhere
when using single sign-on.
I was aware, prior to Single Sign-on (say in 6.1 for example), you could set
the user/pass in the .mfg file in plain text, but as of single sign-on, is
it somehow recorded in a file without my knowledge. My understanding was as
stated below, if you authenticate to the domain and single sign-on is set,
you don't get prompted for user\pass.
Is it possible that someone confused Single Sign-on for the "Allow Multiple
Sessions" setting and the method of skipping a password on versions prior to
Single Sign-on being available?
Some clarification would be great here...
Tim, what version are you speaking about? Can you please identify where the
plain text password is stored?
Aaron Hoyt
Vantage Plastics
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
Calvin Krusen
Sent: Tuesday, January 29, 2008 8:59 AM
Subject: [Vantage] Re: Single Sign On
Calvin
on
> for that user-id.
to
which
start
text
keep
> them in synch.
9.0
feature
the
> There
> fields
PC
> Single
> blank
> > it seems to work.
> > Calvin
change
> > their
this
> > change.
they
> > there any
> > > Matt Caldwell
> > > KERUSSO
> > > P.O. Box 32
> > > Fax: 870-423-3568
of
be
use
> have
> immediately
> > > at: 800-424-0943
Aaron,
The user password is not stored anywhere when using SSO.
You can store a Vantage UserID and Password in the PC's
configuration file. If you just want a PC to automatically login to
Vantage with a specific username and password, enter them in the
default.mfgsys file, and leave SSO as false in config file and
unchecked in the User Security program.
In Vista 8.03.403D, the configuration files on my system are in
c:\client803\client\config\. My standard config file
is "default.mfgsys", which you can open with a text editor.
In the default.mfgsys file there is a section of user settings.
Here is a snippet...
<userSettings>
<!-- provide values for UserID and Password to enable auto-
login -->
<UserID value="" />
<Password value="" />
<SingleSignOn value="true" bool="" />
<DataCollectionUser value="false" bool="" />
<StartSystemMonitor value="true" bool="" />
To determine which config file your various windows shortcuts to
Vantage are using, look at the properties of the shortcut for
the /CONFIG option.
i.e.: C:\client803\client\MfgSys.exe /CONFIG=test.mfgsys
Calvin
somewhere
could set
sign-on, is
is set,
Multiple
versions prior to
where the
> Thanks,
> Aaron Hoyt
> Vantage Plastics
Behalf Of
> Calvin Krusen
after I
on
log
Unix,
not
icon;
enabled, I
they
> Calvin
<snip>
Great info here, thanks!
Of Calvin Krusen
Sent: Tuesday, January 29, 2008 7:59 AM
Calvin
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Tim
on
> for that user-id.
to
which
start
text
keep
> them in synch.
9.0
feature
the
> There
> fields
PC
> Single
> blank
> > it seems to work.
> > Calvin
change
> > their
this
> > change.
they
> > there any
> > > Matt Caldwell
> > > KERUSSO
> > > P.O. Box 32
> > > Fax: 870-423-3568
of
be
use
> have
> immediately
> > > at: 800-424-0943
Thanks for the feedback. Let me get some feedback from my team on
the U/I and P/w storage location.
More soon.
Behalf
> Of Calvin Krusen
> Calvin
Sign-
> on
Vantage
> > for that user-id.
required
> to
can
> which
> start
> text
> keep
> > them in synch.
> 9.0
> feature
> the
> > There
> > fields
> PC
> > Single
> > blank
> > > it seems to work.
> > > Calvin
> change
> > > their
> this
> > > change.
> they
> > > there any
> > > > Matt Caldwell
> > > > KERUSSO
> > > > P.O. Box 32
> > > > Fax: 870-423-3568
use
> of
recipient,
> be
> use
you
> > have
> > immediately
> > > > at: 800-424-0943
 Thank you.
Charles Carden
All epicor does is see which user is logged in to the system and compares it to the record in the UserFile table if they match TADA you are in.
All you should have to do is turn single sign on is to fill out the Domain and the Domain User field in the User File and then flip the setting on the Mfgsys file.
As shown below the user id must also include the domain
Jose C Gomez
Software Engineer
TriGem Company
T: 904.469.1524 mobile
On Wed, Feb 12, 2014 at 9:57 AM, Charles Carden <shadowcar1449@...> wrote:
<div>
  <p><u></u>
 Thank you.
Charles Carden
</div>
<div style="color:rgb(255,255,255);min-height:0px;"></div>
 Thank you.
Charles Carden
