SSRS Packslip Barcode Value Shown
I want to add some barcodes to my packslip. I would like to have the value of the barcode display below the barcode. Instead of creating a duplicate field and put it below the barcode textbox, is there a trick to have the value shown? I am using barcode Datawork 39.
I believe it is all about which font you use… some of the fonts that generate barcodes only display the actual barcode, but others (I believe) support generating the text as well.
Just did a quick websearch for “barcode font with numbers below” and this was one option:
I believe that the DataWork 39 only shows the barcode itself.
Thanks Tim. Will look into that.
